Hello!
I'm trying to upgrade a standalone Debian 11 qube from Qubes OS 4.1
to Debian 12 on Qubes OS 4.2.
I started by making a backup from the standalone on Qubes OS 4.1.
Then I restored it on a fresh Qubes OS 4.2 installation.
Inside that restored standalone I run the upgrade script:
which worked fine, but upgrading Debian 11 -> 12 failed - see below.
The documentation does not yet contain steps for Debian 11 -> 12 yet:
Are there Debian 12 specific issues to consider during the upgrade?
Any idea on how to work around the issue shown below?
thanks!
sed -i 's/bullseye/bookworm/g' /etc/apt/sources.list
sed -i 's/bullseye/bookworm/g' /etc/apt/sources.list.d/qubes-r4.list
apt update
apt upgrade --no-install-recommends
Setting up polkitd (122-3) ...
Failed to check if group polkitd already exists: Connection refused
id: ‘polkitd’: no such user
chown: invalid user: ‘polkitd:root’
dpkg: error processing package polkitd (--configure):
installed polkitd package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of pkexec:
pkexec depends on polkitd (= 122-3); however:
Package polkitd is not configured yet.
dpkg: error processing package pkexec (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of packagekit:
packagekit depends on polkitd; however:
dpkg: error processing package packagekit (--configure):
dpkg: dependency problems prevent configuration of policykit-1:
policykit-1 depends on pkexec (= 122-3); however:
Package pkexec is not configured yet.
policykit-1 depends on polkitd (= 122-3); however:
dpkg: error processing package policykit-1 (--configure):
dpkg: dependency problems prevent configuration of policykit-1-gnome:
policykit-1-gnome depends on polkitd | policykit-1; however:
Package policykit-1 is not configured yet.
dpkg: error processing package policykit-1-gnome (--configure):
dpkg: dependency problems prevent configuration of packagekit-tools:
packagekit-tools depends on packagekit (= 1.2.6-5); however:
Package packagekit is not configured yet.
dpkg: error processing package packagekit-tools (--configure):
dpkg: dependency problems prevent configuration of rtkit:
rtkit depends on polkitd | policykit-1; however:
dpkg: error processing package rtkit (--configure):
dpkg: dependency problems prevent configuration of network-manager-gnome:
network-manager-gnome depends on policykit-1-gnome | polkit-1-auth-agent; however:
Package policykit-1-gnome is not configured yet.
Package polkit-1-auth-agent is not installed.
Package policykit-1-gnome which provides polkit-1-auth-agent is not configured yet.
dpkg: error processing package network-manager-gnome (--configure):
dpkg: dependency problems prevent configuration of colord:
colord depends on polkitd | policykit-1 (>= 0.103); however:
dpkg: error processing package colord (--configure):
dpkg: dependency problems prevent configuration of modemmanager:
modemmanager depends on polkitd | policykit-1; however:
dpkg: error processing package modemmanager (--configure):
dpkg: dependency problems prevent configuration of qubes-core-agent-network-manager:
qubes-core-agent-network-manager depends on network-manager-gnome; however:
Package network-manager-gnome is not configured yet.
qubes-core-agent-network-manager depends on policykit-1; however:
dpkg: error processing package qubes-core-agent-network-manager (--configure):
Errors were encountered while processing:
polkitd
pkexec
packagekit
policykit-1
policykit-1-gnome
packagekit-tools
rtkit
colord
modemmanager
E: Sub-process /usr/bin/dpkg returned an error code (1)
