Hi!
As I had some time, I performed the upgrade to Qubes OS 4.2.0.
Unfortunately there were a few unexpected findings:
* fedora-38 is obsolete already? I thought fedora-37 is???
* my debian-12-dvm template no longer offers Firefox: Qubes settings say: "Application missing in template (firefox-esr.desktop)", However the template is the same as before upgrading Qubes-OS
* The post-reboot phase talked about upgrading to 4.1 once; unfortunately the messages scrolled away.
* Booting after "pre-reboot" showed no UEFI boot entry being present.
* "qmemman.daemon.xswatcher[103730]: do_balance() failed" (see details at end of message)
* Jan 04 22:52:15 dom0 (o-bridge)[111387]: PAM unable to dlopen(/usr/lib64/security/pam_sss.so): /usr/lib64/security/pam_sss.so: cannot open shared object file: No such file or directory
Jan 04 22:52:15 dom0 (o-bridge)[111387]: PAM adding faulty module: /usr/lib64/security/pam_sss.so
* In 4.1 there was a shutdown issue: the LUKS device could not be deactivated as the journal was still writing to the filesystem (see at end, also)
*** After reboot
* "Jan 04 23:56:34 dom0 systemd-escape[381]: Input 'luks-ef8d52d9-a96f-43de-97b4-d73c63443262' is not an absolute file system path, escaping is likely not going to be reversible."
* "Jan 04 23:56:35 dom0 systemd-udevd[437]: /usr/lib/udev/rules.d/50-udev-default.rules:46 Unknown group 'sgx', ignoring"
* "Jan 04 23:56:35 dom0 kernel: firewire_ohci 0000:05:02.0: DMA context ARReq has stopped, error code: evt_unknown
Jan 04 23:56:35 dom0 kernel: firewire_ohci 0000:05:02.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x41
Jan 04 23:56:35 dom0 kernel: firewire_ohci 0000:05:02.0: bad self ID 0/1 (00000000 != ~00000000)"
* "an 04 22:57:01 dom0 systemd-journald[1013]: File /run/log/journal/dd4105a4171541cf81528207ed3decb6/system.journal corrupted or uncleanly shut down, renaming and replacing."
* "Jan 04 22:57:01 dom0 udevadm[1030]: systemd-udev-settle.service is deprecated. Please fix dmraid-activation.service not to pull it in.
Jan 04 22:57:01 dom0 kernel: block device autoloading is deprecated and will be removed."
* "Jan 04 22:57:16 dom0 (systemd)[7250]: PAM unable to dlopen(/usr/lib64/security/pam_sss.so): /usr/lib64/security/pam_sss.so: cannot open shared object file: No such file or directory
Jan 04 22:57:16 dom0 (systemd)[7250]: PAM adding faulty module: /usr/lib64/security/pam_sss.so
Jan 04 22:57:16 dom0 (systemd)[7250]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Could not activate remote peer: activation request failed: unknown unit."
* "Jan 04 22:57:17 dom0 systemd[7250]: Starting dbus-broker.service - D-Bus User Message Bus...
Jan 04 22:57:17 dom0 audit[7188]: USER_START pid=7188 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_selinux,pam_loginuid,pam_selinux,pam_keyinit,pam_namespace,pam_keyinit,pam_limits,pam_systemd,pam_unix,pam_lastlog,pam_umask,pam_lastlog acct="master" exe="/usr/sbin/lightdm" hostname=? addr=? termina>
Jan 04 22:57:17 dom0 dbus-broker-launch[7261]: Service file '/usr/share/dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jan 04 22:57:17 dom0 dbus-broker-launch[7261]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
Jan 04 22:57:17 dom0 dbus-broker-launch[7261]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
Jan 04 22:57:17 dom0 dbus-broker-launch[7261]: Service file '/usr/share/dbus-1/services/dbus-qubes-app-menu.service' is not named after the D-Bus name 'org.qubesos.appmenu'.
Jan 04 22:57:17 dom0 systemd[7250]: Started dbus-broker.service - D-Bus User Message Bus."
* "Jan 04 23:01:40 dom0 qubes.SyncAppMenus+-debian-12[9218]: Warning: ignoring key 'Name' of display-im6.q16
Jan 04 23:01:41 dom0 qubes\.SyncAppMenus\+\-debian\-12\[9218\]: Warning: not creating/updating '/home/master/\.local/share/qubes\-appmenus/debian\-12/apps\.templates/display\-im6\.q16\.desktop' because of missing 'Name' key" ???
* "Jan 05 00:04:25 dom0 qmemman.systemstate[4900]: Xen free = 137217483 too small for satisfy assignments! assigned_but_unused=121323564, domdict={'0': {'memory_current': 4278190080, 'memory_actual': 4294967296, 'memory_maximum': 4294967296, 'mem_used': 1505382400, 'id': '0', 'last_target': 4294967296, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '1': {'memory_current': 402698240, 'memory_actual': 402698240, 'memory_maximum': 419430400, 'mem_used': None, 'id': '1', 'last_target': 402653184, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '2': {'memory_current': 150994944, 'memory_actual': 150994944, 'memory_maximum': 150994944, 'mem_used': None, 'id': '2', 'last_target': 150994944, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '3': {'memory_current': 1503051776, 'memory_actual': 1519765398, 'memory_maximum': 4194304000, 'mem_used': 454008832, 'id': '3', 'last_target': 1537672796, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '4': {'memory_current': 1752047616, 'memory_actual': 1768759535, 'memory_maximum': 4194304000, 'mem_used': 541683712, 'id': '4', 'last_target': 1788542049, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '16': {'memory_current': 3663560704, 'memory_actual': 3680273744, 'memory_maximum': 4294967296, 'mem_used': 1172312064, 'id': '16', 'last_target': 3592995773, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '17': {'memory_current': 2759909376, 'memory_actual': 2776624523, 'memory_maximum': 4194304000, 'mem_used': 896569344, 'id': '17', 'last_target': 2776624523, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '18': {'memory_current': 2069704704, 'memory_actual': 2086420452, 'memory_maximum': 4194304000, 'mem_used': 653537280, 'id': '18', 'last_target': 2086420452, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}}"
