I have the following *.sls in my saltsetup:
{% if salt’pkg.version_cmp’ < 0 %}
move broken AX260 wifi blob out of the way:
file.rename:
- name: /usr/lib/firmware/iwlwifi-ty-a0-gf-ao.pnvm.xz.bak
- source: /usr/lib/firmware/iwlwifi-ty-a0-gf-ao.pnvm.xz
- force: True
- runas: root
{% endif %}
This is supposed to automate moving linux firmware out of the way that interferes with my wifi card’s operation under certain non-cutting edge kernel versions (as present in QubesOS).
I can run this *.slsfine on dom0 (where it doesn’t make much sense, respectively the change isn’t necessary), but if I target the templates (and particularly the one sys-net is based on), salt balks on the first line. There’s a lot of traceback, but the most readable message appears to be along the lines of
Jinja error: get() missing 1 required positional argument: 'default'
Does anyone have any pointers as to what may be going on here, how to better debug (error output from dom0 → Email VM?) and how to fix?
Thanks in advance.
Joh
