I restored my system from a laptop running Qubes 4.0 recently
The template for my gpg domain is based on debian-10. I restored both the gpg domain and the template into the new system, but the gpg domain won’t start
It seems to get stuck waiting for the xvdd device to attach to the VM.
/var/log/xen/console/guest-gpg.log
blkfront: xvda: flush diskcache: enabled; persistent grants;: enabled; indirect descriptors: enabled; bounce buffer: enabled
xvda: xvda1 xvda2 xvda3
blkfront: xvdb: flush diskcache: enabled; persistent grants;: enabled; indirect descriptors: enabled; bounce buffer: enabled
blkfront: xvdc: flush diskcache: enabled; persistent grants;: enabled; indirect descriptors: enabled; bounce buffer: enabled
xenbus_probe_frontend: Waiting for devices to initialize: 25s…20s…15s…10s…5s…0s…
before the VM shuts down
If I boot another VM (ssh /lan) which uses the same template, I get this instead
blkfront: xvdd: flush diskcache: enabled; persistent grants;: enabled; indirect descriptors: enabled; bounce buffer: enabled
Waiting for /dev/xvdd device…
/dev/xvdd: Can’t open blockdev
VM boots anyway
I googled that line and see references to /var/log/xen/xen-hotplug.log - this file is empty
I’m wondering how old that VM is, maybe its come from Qubes 3.2 → 4.0 → 4.1 and finally it’s running into bother?
Other VM’s seem to boot from that template which is odd, I’m going to try transfer the data to a fresh qube, transfer THAT to the new system and hopefully it works, but otherwise I’m at a loss here
