Joanna:
I tried another stick (a 16GB); and now the Install Program (full graphics and troubleshooting text modes) tells me that the install cannot continue since there is no root (/) partition.
IIRC, All we need was something larger than 10GB.
Was there something I needed to do, other than blanking the drive via formatting for the install?
I understand that you’ve installed on USB3 Sticks. Any luck on the USB2 Gen Drives?
Thank you
During partitioning, you should define mappings between partitions and mount points.
In your case, you should configure the partition to be used as /
I formatted the pen drive via Windoze. That is the error message the Qubes installer has indicated.
So, I’ll need to boot up Linux; and partition the USB Flash Drive as a “/” root partition deliberately, or
should I format the pen drive on linux, then proceed? (6 and a half-dozen or another - ^_^)
Thanks.
Installer gives you option to partition it there. There are some predefined
layouts ("LVM" by default), but there is also option to select partitions
manually. I suggest that you choose it, remove all the partitions from this
stick (this done by windows) and select automatic layout proposed by installer.
