Solved! You have to enable permissive mode for the cards pci addresses. It works with qubes 4.0 and up. For older versions below refer to this google group. Steps:
0. Turn off sys-net.
- Go to sys-net’s Qubes Settigs in Qubes Manager.
- Chose “Devices” tab.
- Remove all entries for network card from qube that are associated to qube. (Remember all the PCI addresses)
- In dom0 terminal type:
qvm-pci attach --persistent --option permissive=true sys-net dom0:e1_00.1
(Substitute your own cards pci address you remember from step 3. for e1_00.1 ! Note the underscore!!!) - Repeat step 4 for all pci addresses of your card.
- Done.
raah...@gmail.com a következőt írta (2017. május 8., hétfő, 21:08:43 UTC+2):
