hey , i need your help with qubes and installing partition on the usb to save files… do you do it on the windows while you download Qubes in the terminal or once your first running qubes ?
Tray G:
save files.. do you do it on the windows while you download Qubes in the
If you're talking about creating a USB drive to install Qubes, see Installation guide | Qubes OS.
If you want to format a USB drive for use with Qubes once you have it installed, it will be most straightforward to format it from Qubes. There are some Microsoft FAT/NTFS formats Linux can work with out of the box, but you have to add support for others it does not, which you can avoid by formatting under Qubes/Linux in the first place.
