I’m currently evaluating the possibility of moving my workstation to Qubes OS and ran into a problem.
It’s using an SSD for Qubes OS, but I want to use HDDs with RAID6 to hold qubes data.
I’ve been using the secondary storage guide and slightly altered it for RAID6:
I ran “sudo cryptsetup luksFormat --hash=sha512 --key-size=512 --cipher=aes-xts-plain64 --verify-passphrase /dev/sdx” for 5 test HDDs.
Then I added their UUID to /etc/crypttab and rebooted.
After than I ran “sudo pvcreate /dev/mapper/luks-[UUID]” for the 5 drives.
I created a volume group with “sudo vgcreate qubeshd0 /dev/mapper/luks-UUID1 /dev/mapper/luks-UUID2 …”
Then I did this:
sudo lvcreate -i 3 --type raid6 -L 10G -n poolhd0 qubeshd0
sudo lvconvert --thinpool qubeshd0/poolhd0
sudo lvextend -l +100%FREE qubeshd0/poolhd0
This seems to give me a RAID6 thin pool with the correct size. I created VMs and used this pool for data storage and everything seems to work fine. So far so good.
After that I wanted to go through some other scenarios like adding HDDs to the RAID (growing it) or replacing faulty hdds.
I was able to add a new HDD to the volume group but after that I got stuck, since I was unable to add the new free space to the RAID6.
Everything I tried gave me an error. One of them was that thin pool did not support the operation. I also tried it without converting to thin pool but still was unable to extend the RAID6.
Things like this are the reason why I wanted to simulate/evaluate everything first before actually moving everything.
How can I extend the 5 hdd RAID6 to 6 hdds (and higher)? Over time the final target would be to grow the RAID to around 10-12 HDDs.
Was that even correct how I implemented it? What would be the best way to accomplish it?
I'm currently evaluating the possibility of moving my workstation to Qubes OS and ran into a problem.
It's using an SSD for Qubes OS, but I want to use HDDs with RAID6 to hold qubes data.
I've been using the secondary storage guide and slightly altered it for RAID6:
I ran "sudo cryptsetup luksFormat --hash=sha512 --key-size=512 --cipher=aes-xts-plain64 --verify-passphrase /dev/sdx" for 5 test HDDs.
I'm not an expert on this, but why do you cryptsetup each HDD instead of cryptsetup the RAID device? The data on HDD still should be encrypted.
After than I ran "sudo pvcreate /dev/mapper/luks-[UUID]" for the 5 drives.
I created a volume group with "sudo vgcreate qubeshd0 /dev/mapper/luks-UUID1 /dev/mapper/luks-UUID2 ...."
Then I did this:
You want to extend the RAID, , i.e. the PV, not add a single HDD as PV, right?
I think you must reserve "RAID slots" (number of disks to expect" when creating the RAID. Maybe you can tune that later, but I'm unsure.
