Hello,
I was using Qubes for about 3 months and didn’t use it last month.
Yesterday it wouldn’t boot.
Using Qubes rescue didn’t help. After typing passphrase it says Linux system not found so it doesn’t mount.
So i found a way to mount disk manually. Going through directories found out that boot folder is empty.
Also if that is not an option i want to save my files but seems like private.img are missing. There is only icon.png file in VM folders.
Is there any way to recover boot files so i can boot it again or at least save files from VMs somehow?
Qubes User:
Hello,
I was using Qubes for about 3 months and didn't use it last month.
Yesterday it wouldn't boot.
Using Qubes rescue didn't help. After typing passphrase it says Linux system not
found so it doesn't mount.
Try booting with a LiveCD distribution. Scan and mount the LVM thin volumes with vgchange -ay. You may need to install a package to support LVM thin. You should be able to pull data from the VMs that way.
