Hello Qubes-Users,
I just installed Qubes version 4.0.3 on a new Thinkpad L13 Yoga (March 2020)
Issue:
I cannot connect to the Internet.
Inside the sys-net cube at the command line I enter:
`lspci -k`
and the result looks fine:
Network controller: Intel corporation Wireless-AC 9462
Subsystem: Intel Corporation Device 0030
Kernel Driver in use iwlwifi
Kernel modules: iwlwifi
However, when I run `nmcli dev wifi` there is no result. It's empty.
Note I have enabled wireless device using ifconfig.
Everything is run from the sys-net terminal.
Can you help me troubleshoot this so I can connect to the Internet?
Thanks in advance for your help!
-GJD
