I’ve installed Whonix 16 on my Qubes OS R4.0 system - and - have switched ‘sys-whonix’ to ‘whonix-gw-16’ as well as ‘anon-whonix’ to ‘whonix-ws-16’.
Everything seems to work fine - but - Qubes Updater reports that updates are available for ‘whonix-[gw | ws]-16’ but always fails to update the templates with error msgs similar to
managed the download on 4.0.4 in the last days without any issues. Just did it with the qubes-dom0-update command and the enablerepo=community switch. No other commands or work. It just went through like it always do with downloads & installs of new templates.
Sorry, if I couldn’t help more.
My initial problem was not with the ‘upgrade’ from 15 to 16 - but - with the way my Qubes OS instance behaved after having Whonix 15 & 16 installed in parallel. - ‘Unman’ did resolve that issue already.
What I’m still interested in & continue to struggeling with is "how to ensure that AppVMs & TemplateVMs are / can be time-synced " …
I don't want to adjust the time for the two Whonix templates manually to
the (wrong?) CET values, whenever an update is necessary.
I don't think I had this issue with Whonix 15 & believe it only started
with Whonix 16.
Do you have any ideas or suggestions?
Check dom0's clockvm with "qubes-prefs" in a terminal. It's probably sys-net. Confirm the timezone and time are set correctly inside sys-net (or your clockvm if different). If that doesn't do it, and you can afford it, might try a fresh install of 4.1rc2, and making sure to set the correct timezone on install. Hard to know which time zone setting is incorrect.
I don’t want to adjust the time for the two Whonix templates manually to
I don’t think I had this issue with Whonix 15 & believe it only started
with Whonix 16.
Check dom0’s clockvm with “qubes-prefs” in a terminal. It’s probably
sys-net.
Yes it is. Here are the complete preferences:
[vr@dom0 ~]$ qubes-prefs
check_updates_vm D True
clockvm - sys-net
default_dispvm - fedora-34-dvm
default_kernel - 5.4.143-1.fc25
default_netvm - sys-firewall
default_pool D lvm
default_pool_kernel - linux-kernel
default_pool_private D lvm
default_pool_root D lvm
default_pool_volatile D lvm
default_qrexec_timeout D 60
default_shutdown_timeout D 60
default_template - fedora-34
management_dispvm - default-mgmt-dvm
stats_interval D 3
updatevm - sys-firewall
[vr@dom0 ~]$
Here are the results of ‘timedatectl’:
[user@sys-net ~]$ timedatectl
Local time: Sat 2021-11-20 18:34:11 CET
Universal time: Sat 2021-11-20 17:34:11 UTC
RTC time: Sat 2021-11-20 17:34:11
Time zone: Europe/Berlin (CET, +0100)
System clock synchronized: no
NTP service: inactive
RTC in local TZ: no
[user@sys-net ~]$
If that doesn’t do it, and you can
incorrect.
A check with / upgrade to 4.1rc2 is not an option for me. - At least not in November …
Any idea why this isn't running? If your hardware clock is close enough to the right time, it might not matter, but can't be helping things. It's showing as synchronized & active on my sys-net. I'm running 4.1, but pretty sure it showed the same on 4.0.
