When I verify my backups, it happens ~instantaneously. It used to take
hours, because it would extract every VM backup and verify it. Judging
by the logs, it's only verifying dom0.
Unless something has changed with how Qubes verifies its backups, there
may be a bug that causes verification to only check dom0, rather than
verifying the AppVMs as well.
This is really bad, because what I care about is the data in the
AppVMs... being able to restore the AppVMs is more important than being
able to restore dom0!
It's possible to create "backup profiles," but I haven't personally used them, so I'm not familiar with the details of how they work. This option is mentioned in the `--help` text for qvm-backup but not qvm-backup-restore.
It looks like the profiles are stored in /etc/qubes/backup/. I checked
that directory and there are no profiles, so that can't be the problem.
Unfortunately at this point I'm all out of ideas for troubleshooting
this -- even though it's a very important issue! Unverified backups are
very dangerous, and I've caught problems before because backups failed
to verify.
When it starts restoring, it shows that none of my VMs will be restored,
except for dom0:
The following VMs are included in the backup:
name | type | template | netvm | label |
dom0 | AdminVM | n/a | (default) | black |
myvm | StandaloneVM | n/a | my-net-vm-xxxxx | orange | <-- Excluded from restore
my-other-vm-xxxxxxx | AppVM | debian-10 | (default) | blue | <-- Excluded from restore
another-vm-xx | AppVM | fedora-33 | (default) | green | <-- Excluded from restore
[... continuing for the list of all VMs ...]
It acts as if you accidentally passed a whitelist of VMs to restore,
and none of them are part of the backup file. Some ideas:
- - If you posted a simplified version instead of the command you're
really using, make sure there's no extra argument after the backup
file
- - Use quoted shell variables, e.g. "$BACKUP_FILE" with quotation marks
- - Just to ensure that nothing's somehow tripping up the options
parser, try using = instead of a space for option arguments, e.g.
--dest-vm="$DEST_VM"
