[qubes-users] QSB-108: Transitive Scheduler Attacks (XSA-471)
Dear Qubes Community,
We have published [Qubes Security Bulletin (QSB) 108: Transitive Scheduler Attacks (XSA-471)](qubes-secpack/QSBs/qsb-108-2025.txt at 5da25fc8fbece540ad4594235cf7ee5e7a751fbb · QubesOS/qubes-secpack · GitHub). The text of this QSB and its accompanying cryptographic signatures are reproduced below, followed by a general explanation of this announcement and authentication instructions.
## Qubes Security Bulletin 108
             ---===[ Qubes Security Bulletin 108 ]===---
                              2025-07-08
Changelog
2025-07-08: Original QSB
2025-07-11: Revise language
User action
Continue to update normally [1] in order to receive the security updates
described in the "Patching" section below. No other user action is
required in response to this QSB.
Summary
On 2025-07-08, the Xen Project published XSA-471, "x86: Transitive
Scheduler Attacks" (CVE-2024-36350, CVE-2024-36357) [3]:
> Researchers from Microsoft and ETH Zurich have discovered several new
> speculative sidechannel attacks which bypass current protections.
> They are detailed in a paper titled "Enter, Exit, Page Fault, Leak:
> Testing Isolation Boundaries for Microarchitectural Leaks".
> Two issues, which AMD have named Transitive Scheduler Attacks, utilise
> timing information from instruction execution.  These are:
>   * CVE-2024-36350: TSA-SQ (TSA in the Store Queues)
>   * CVE-2024-36357: TSA-L1 (TSA in the L1 data cache)
For more information, see also [4], [5] and [6].
Impact
On affected systems, an attacker who manages to compromise a qube may be
able to use it to infer the contents of arbitrary system memory,
including memory assigned to other qubes.
As noted in XSA-471, the paper [6] also describes two Rogue System
Register Read (sometimes called Spectre-v3a) attacks, namely
CVE-2024-36348 and CVE-2045-36349. However, these are not believed to
affect the security of Qubes OS.
Affected systems
Only AMD CPUs with Zen 3 or Zen 4 cores are believed to be affected
(CPUID family 0x19). For a more detailed list, see [5].
Patching
As of this writing, AMD has published only non-server CPU microcode
updates via the linux-firmware repository. [7] They have not yet
published microcode updates for server CPUs. When this happens, we will
provide an updated amd-ucode-firmware package. Users with server CPUs
may be able to obtain the relevant microcode update via a motherboard
firmware (BIOS/UEFI) update, but this depends on the motherboard vendor
making such an update available. The appendix of [4] (page 5) contains a
table showing the minimum microcode version required for mitigating
transient scheduler attacks for different CPUs. The required microcode
version (not to be confused with the amd-ucode-firmware package version)
depends on the CPUID family/model/stepping. Users can compare the
values from the table with their own system's family/model/stepping and
current microcode version, which can be viewed by executing the command
`cat /proc/cpuinfo` in a dom0 terminal.
On affected systems with non-server CPUs, the following packages contain
security updates that address the vulnerabilities described in this
bulletin:
  For Qubes 4.2, in dom0:
  - Xen packages, version 4.17.5-10
  - amd-ucode-firmware version 20250708-1
by the community. [2] Once available, the packages should be installed
via the Qubes Update tool or its command-line equivalents. [1]
effect.
passphrase to new PCR values, as PCR18+19 will change due to the new Xen
binaries.
Credits
See the original Xen Security Advisory and linked publications.
References
[1] https://www.qubes-os.org/doc/how-to-update/
[2] https://www.qubes-os.org/doc/testing/
[3] https://xenbits.xen.org/xsa/advisory-471.html
[4] https://www.amd.com/content/dam/amd/en/documents/resources/bulletin/technical-guidance-for-mitigating-transient-scheduler-attacks.pdf
[5] https://www.amd.com/en/resources/product-security/bulletin/amd-sb-7029.html
[6] https://www.microsoft.com/en-us/research/publication/enter-exit-page-fault-leak-testing-isolation-boundaries-for-microarchitectural-leaks/
[7] https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/amd-ucode/README
The Qubes Security Team
*Source*: [qsb-108-2025.txt](qubes-secpack/QSBs/qsb-108-2025.txt at 5da25fc8fbece540ad4594235cf7ee5e7a751fbb · QubesOS/qubes-secpack · GitHub)
## [Marek Marczykowski-Górecki](Team | Qubes OS)'s PGP signature
*Source*: [qsb-108-2025.txt.sig.simon](qubes-secpack/QSBs/qsb-108-2025.txt.sig.simon at 5da25fc8fbece540ad4594235cf7ee5e7a751fbb · QubesOS/qubes-secpack · GitHub)
## What is the purpose of this announcement?
The purpose of this announcement is to inform the Qubes community that a new Qubes security bulletin (QSB) has been published.
## What is a Qubes security bulletin (QSB)?
A Qubes security bulletin (QSB) is a security announcement issued by the [Qubes security team](Qubes OS project security center | Qubes OS). A QSB typically provides a summary and impact analysis of one or more recently-discovered software vulnerabilities, including details about patching to address them. For a list of all QSBs, see [Qubes security bulletins (QSBs)](Qubes security bulletins (QSBs) | Qubes OS).
## Why should I care about QSBs?
QSBs tell you what actions you must take in order to protect yourself from recently-discovered security vulnerabilities. In most cases, security vulnerabilities are addressed by [updating normally](How to update | Qubes OS). However, in some cases, special user action is required. In all cases, the required actions are detailed in QSBs.
## What are the PGP signatures that accompany QSBs?
A [PGP](Pretty Good Privacy - Wikipedia) signature is a cryptographic [digital signature](Digital signature - Wikipedia) made in accordance with the [OpenPGP](Pretty Good Privacy - Wikipedia) standard. PGP signatures can be cryptographically verified with programs like [GNU Privacy Guard (GPG)](https://gnupg.org/). The Qubes security team cryptographically signs all QSBs so that Qubes users have a reliable way to check whether QSBs are genuine. The only way to be certain that a QSB is authentic is by verifying its PGP signatures.
## Why should I care whether a QSB is authentic?
A forged QSB could deceive you into taking actions that adversely affect the security of your Qubes OS system, such as installing malware or making configuration changes that render your system vulnerable to attack. Falsified QSBs could sow fear, uncertainty, and doubt about the security of Qubes OS or the status of the Qubes OS Project.
## How do I verify the PGP signatures on a QSB?
The following command-line instructions assume a Linux system with `git` and `gpg` installed. (For Windows and Mac options, see [OpenPGP software](Verifying signatures | Qubes OS).)
1. Obtain the Qubes Master Signing Key (QMSK), e.g.:
   $ gpg --fetch-keys https://keys.qubes-os.org/keys/qubes-master-signing-key.asc
   gpg: directory '/home/user/.gnupg' created
   gpg: keybox '/home/user/.gnupg/pubring.kbx' created
   gpg: requesting key from 'https://keys.qubes-os.org/keys/qubes-master-signing-key.asc'
   gpg: /home/user/.gnupg/trustdb.gpg: trustdb created
   gpg: key DDFA1A3E36879494: public key "Qubes Master Signing Key" imported
   gpg: Total number processed: 1
   gpg:               imported: 1
   (For more ways to obtain the QMSK, see [How to import and authenticate the Qubes Master Signing Key](Verifying signatures | Qubes OS).)
2. View the fingerprint of the PGP key you just imported. (Note: `gpg>` indicates a prompt inside of the GnuPG program. Type what appears after it when prompted.)
   $ gpg --edit-key 0x427F11FD0FAA4B080123F01CDDFA1A3E36879494
   gpg (GnuPG) 2.2.27; Copyright (C) 2021 Free Software Foundation, Inc.
   This is free software: you are free to change and redistribute it.
   There is NO WARRANTY, to the extent permitted by law.
   pub  rsa4096/DDFA1A3E36879494
        created: 2010-04-01  expires: never       usage: SC
        trust: unknown       validity: unknown
   [ unknown] (1). Qubes Master Signing Key
   > fpr
   pub   rsa4096/DDFA1A3E36879494 2010-04-01 Qubes Master Signing Key
    Primary key fingerprint: 427F 11FD 0FAA 4B08 0123  F01C DDFA 1A3E 3687 9494
3. *Important*: At this point, you still don't know whether the key you just imported is the genuine QMSK or a forgery. In order for this entire procedure to provide meaningful security benefits, you *must* authenticate the QMSK out-of-band. *Do not skip this step*! The standard method is to obtain the QMSK fingerprint from *multiple independent sources in several different ways* and check to see whether they match the key you just imported. For more information, see [How to import and authenticate the Qubes Master Signing Key](Verifying signatures | Qubes OS).
   *Tip*: After you have authenticated the QMSK out-of-band to your satisfaction, record the QMSK fingerprint in a safe place (or several) so that you don't have to repeat this step in the future.
4. Once you are satisfied that you have the genuine QMSK, set its trust level to 5 ("ultimate"), then quit GnuPG with `q`.
   > trust
   Please decide how far you trust this user to correctly verify other users' keys
   (by looking at passports, checking fingerprints from different sources, etc.)
     1 = I don't know or won't say
     2 = I do NOT trust
     3 = I trust marginally
     4 = I trust fully
     5 = I trust ultimately
     m = back to the main menu
   Your decision? 5
   Do you really want to set this key to ultimate trust? (y/N) y
        trust: ultimate      validity: unknown
   Please note that the shown key validity is not necessarily correct
   unless you restart the program.
   > q
5. Use Git to clone the qubes-secpack repo.
   $ git clone https://github.com/QubesOS/qubes-secpack.git
   Cloning into 'qubes-secpack'...
   remote: Enumerating objects: 4065, done.
   remote: Counting objects: 100% (1474/1474), done.
   remote: Compressing objects: 100% (742/742), done.
   remote: Total 4065 (delta 743), reused 1413 (delta 731), pack-reused 2591
   Receiving objects: 100% (4065/4065), 1.64 MiB | 2.53 MiB/s, done.
   Resolving deltas: 100% (1910/1910), done.
6. Import the included PGP keys. (See our [PGP key policies](Qubes security pack (qubes-secpack) | Qubes OS) for important information about these keys.)
   $ gpg --import qubes-secpack/keys/*/*
   gpg: key 063938BA42CFA724: public key "Marek Marczykowski-Górecki (Qubes OS signing key)" imported
   gpg: qubes-secpack/keys/core-devs/retired: read error: Is a directory
   gpg: no valid OpenPGP data found.
   gpg: key 8C05216CE09C093C: 1 signature not checked due to a missing key
   gpg: key 8C05216CE09C093C: public key "HW42 (Qubes Signing Key)" imported
   gpg: key DA0434BC706E1FCF: public key "Simon Gaiser (Qubes OS signing key)" imported
   gpg: key 8CE137352A019A17: 2 signatures not checked due to missing keys
   gpg: key 8CE137352A019A17: public key "Andrew David Wong (Qubes Documentation Signing Key)" imported
   gpg: key AAA743B42FBC07A9: public key "Brennan Novak (Qubes Website & Documentation Signing)" imported
   gpg: key B6A0BB95CA74A5C3: public key "Joanna Rutkowska (Qubes Documentation Signing Key)" imported
   gpg: key F32894BE9684938A: public key "Marek Marczykowski-Górecki (Qubes Documentation Signing Key)" imported
   gpg: key 6E7A27B909DAFB92: public key "Hakisho Nukama (Qubes Documentation Signing Key)" imported
   gpg: key 485C7504F27D0A72: 1 signature not checked due to a missing key
   gpg: key 485C7504F27D0A72: public key "Sven Semmler (Qubes Documentation Signing Key)" imported
   gpg: key BB52274595B71262: public key "unman (Qubes Documentation Signing Key)" imported
   gpg: key DC2F3678D272F2A8: 1 signature not checked due to a missing key
   gpg: key DC2F3678D272F2A8: public key "Wojtek Porczyk (Qubes OS documentation signing key)" imported
   gpg: key FD64F4F9E9720C4D: 1 signature not checked due to a missing key
   gpg: key FD64F4F9E9720C4D: public key "Zrubi (Qubes Documentation Signing Key)" imported
   gpg: key DDFA1A3E36879494: "Qubes Master Signing Key" not changed
   gpg: key 1848792F9E2795E9: public key "Qubes OS Release 4 Signing Key" imported
   gpg: qubes-secpack/keys/release-keys/retired: read error: Is a directory
   gpg: key D655A4F21830E06A: public key "Marek Marczykowski-Górecki (Qubes security pack)" imported
   gpg: key ACC2602F3F48CB21: public key "Qubes OS Security Team" imported
   gpg: qubes-secpack/keys/security-team/retired: read error: Is a directory
   gpg: key 4AC18DE1112E1490: public key "Simon Gaiser (Qubes Security Pack signing key)" imported
   gpg: Total number processed: 17
   gpg:               imported: 16
   gpg:              unchanged: 1
   gpg: marginals needed: 3  completes needed: 1  trust model: pgp
   gpg: depth: 0  valid:   1  signed:   6  trust: 0-, 0q, 0n, 0m, 0f, 1u
   gpg: depth: 1  valid:   6  signed:   0  trust: 6-, 0q, 0n, 0m, 0f, 0u
7. Verify signed Git tags.
   $ cd qubes-secpack/
   $ git tag -v `git describe`
   object 266e14a6fae57c9a91362c9ac784d3a891f4d351
   type commit
   tag marmarek_sec_266e14a6
   tagger Marek Marczykowski-Górecki 1677757924 +0100
   Tag for commit 266e14a6fae57c9a91362c9ac784d3a891f4d351
   gpg: Signature made Thu 02 Mar 2023 03:52:04 AM PST
   gpg:                using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A
   gpg: Good signature from "Marek Marczykowski-Górecki (Qubes security pack)" [full]
   The exact output will differ, but the final line should always start with `gpg: Good signature from...` followed by an appropriate key. The `[full]` indicates full trust, which this key inherits in virtue of being validly signed by the QMSK.
8. Verify PGP signatures, e.g.:
   $ cd QSBs/
   $ gpg --verify qsb-087-2022.txt.sig.marmarek qsb-087-2022.txt
   gpg: Signature made Wed 23 Nov 2022 04:05:51 AM PST
   $ gpg --verify qsb-087-2022.txt.sig.simon qsb-087-2022.txt
   gpg: Signature made Wed 23 Nov 2022 03:50:42 AM PST
   gpg:                using RSA key EA18E7F040C41DDAEFE9AA0F4AC18DE1112E1490
   gpg: Good signature from "Simon Gaiser (Qubes Security Pack signing key)" [full]
   $ cd ../canaries/
   $ gpg --verify canary-034-2023.txt.sig.marmarek canary-034-2023.txt
   gpg: Signature made Thu 02 Mar 2023 03:51:48 AM PST
   $ gpg --verify canary-034-2023.txt.sig.simon canary-034-2023.txt
   gpg: Signature made Thu 02 Mar 2023 01:47:52 AM PST
   Again, the exact output will differ, but the final line of output from each `gpg --verify` command should always start with `gpg: Good signature from...` followed by an appropriate key.
For this announcement (QSB-108), the commands are:
$ gpg --verify qsb-108-2025.txt.sig.marmarek qsb-108-2025.txt
$ gpg --verify qsb-108-2025.txt.sig.simon qsb-108-2025.txt
You can also verify the signatures directly from this announcement in addition to or instead of verifying the files from the qubes-secpack. Simply copy and paste the QSB-108 text into a plain text file and do the same for both signature files. Then, perform the same authentication steps as listed above, substituting the filenames above with the names of the files you just created.
