We have just published Qubes Security Bulletin (QSB) 067: Multiple RPM
vulnerabilities. The text of this QSB is reproduced below. This QSB and
its accompanying signatures will always be available in the Qubes
Security Pack (qubes-secpack).
View QSB-067 in the qubes-secpack:
Learn about the qubes-secpack, including how to obtain, verify, and read it:
Hi, I’ve tried to install the updates. Even after removing systemtap and when using --clean, I am unable to install it. IIUC, I am trying to install it too soon:
$ sudo qubes-dom0-update --enablerepo=qubes-dom0-security-testing --clean
Using sys-firewall as UpdateVM to download updates for Dom0; this may take some time…
40 files removed
Fedora 25 - x86_64 - Updates 272 kB/s | 24 MB 01:29
Fedora 25 - x86_64 3.6 MB/s | 50 MB 00:14
Qubes Dom0 Repository (updates) 1.3 MB/s | 1.3 MB 00:01
Qubes Dom0 Repository (security-testing) 1.5 MB/s | 3.0 MB 00:02
determining the fastest mirror (14 hosts)… done.-- B/s | 0 B --:-- ETA
Qubes Templates repository 2.2 kB/s | 5.9 kB 00:02
Error:
Problem 1: problem with installed package satyr-0.21-2.fc25.x86_64
cannot install the best update candidate for package satyr-0.21-2.fc25.x86_64
nothing provides librpm.so.8()(64bit) needed by satyr-0.21-2.1.fc25.x86_64
Problem 2: problem with installed package qubes-core-dom0-linux-4.0.28-1.fc25.x86_64
cannot install the best update candidate for package qubes-core-dom0-linux-4.0.28-1.fc25.x86_64
nothing provides rpm >= 4.14 needed by qubes-core-dom0-linux-4.0.29-1.fc25.x86_64
Problem 3: problem with installed package python3-hawkey-0.6.4-3.fc25.x86_64
cannot install the best update candidate for package python3-hawkey-0.6.4-3.fc25.x86_64
nothing provides librpm.so.8()(64bit) needed by python3-hawkey-0.6.4-3.1.fc25.x86_64
nothing provides librpmio.so.8()(64bit) needed by python3-hawkey-0.6.4-3.1.fc25.x86_64
Problem 4: problem with installed package libsolv-0.6.29-2.fc25.x86_64
cannot install the best update candidate for package libsolv-0.6.29-2.fc25.x86_64
nothing provides librpm.so.8()(64bit) needed by libsolv-0.6.29-2.1.fc25.x86_64
Problem 5: problem with installed package hawkey-0.6.4-3.fc25.x86_64
cannot install the best update candidate for package hawkey-0.6.4-3.fc25.x86_64
nothing provides librpm.so.8()(64bit) needed by hawkey-0.6.4-3.1.fc25.x86_64
nothing provides librpmio.so.8()(64bit) needed by hawkey-0.6.4-3.1.fc25.x86_64
Problem 6: problem with installed package drpm-0.3.0-3.fc25.x86_64
cannot install the best update candidate for package drpm-0.3.0-3.fc25.x86_64
nothing provides librpm.so.8()(64bit) needed by drpm-0.3.0-3.1.fc25.x86_64
nothing provides librpmio.so.8()(64bit) needed by drpm-0.3.0-3.1.fc25.x86_64
Problem 7: problem with installed package deltarpm-3.6-17.fc25.x86_64
cannot install the best update candidate for package deltarpm-3.6-17.fc25.x86_64
nothing provides librpm.so.8()(64bit) needed by deltarpm-3.6-17.1.fc25.x86_64
nothing provides librpmio.so.8()(64bit) needed by deltarpm-3.6-17.1.fc25.x86_64
Problem 8: problem with installed package createrepo_c-libs-0.10.0-6.fc25.x86_64
cannot install the best update candidate for package createrepo_c-libs-0.10.0-6.fc25.x86_64
nothing provides librpm.so.8()(64bit) needed by createrepo_c-libs-0.10.0-6.1.fc25.x86_64
nothing provides librpmio.so.8()(64bit) needed by createrepo_c-libs-0.10.0-6.1.fc25.x86_64
Problem 9: problem with installed package createrepo_c-0.10.0-6.fc25.x86_64
cannot install the best update candidate for package createrepo_c-0.10.0-6.fc25.x86_64
nothing provides librpm.so.8()(64bit) needed by createrepo_c-0.10.0-6.1.fc25.x86_64
nothing provides librpmio.so.8()(64bit) needed by createrepo_c-0.10.0-6.1.fc25.x86_64
Problem 10: problem with installed package PackageKit-1.1.5-1.fc25.x86_64
cannot install the best update candidate for package PackageKit-1.1.5-1.fc25.x86_64
nothing provides librpm.so.8()(64bit) needed by PackageKit-1.1.5-1.1.fc25.x86_64
nothing provides librpmio.so.8()(64bit) needed by PackageKit-1.1.5-1.1.fc25.x86_64
Problem 11: problem with installed package python2-deltarpm-3.6-17.fc25.x86_64
cannot install the best update candidate for package python2-deltarpm-3.6-17.fc25.x86_64
package python2-deltarpm-3.6-17.1.fc25.x86_64 requires deltarpm(x86-64) = 3.6-17.1.fc25, but none of the providers can be installed
(try to add ‘–skip-broken’ to skip uninstallable packages)
Hi, I've tried to install the updates. Even after removing systemtap and
it too soon:
some time...
40 files removed
01:29
00:14
00:01
00:02
determining the fastest mirror (14 hosts).. done.-- B/s | 0 B --:--
ETA
00:02
Error:
- cannot install the best update candidate for package
- nothing provides librpm.so.8()(64bit) needed by
- nothing provides rpm >= 4.14 needed by
- nothing provides librpmio.so.8()(64bit) needed by
- package python2-deltarpm-3.6-17.1.fc25.x86_64 requires deltarpm(x86-64)
(try to add '--skip-broken' to skip uninstallable packages)
Regards,
Vít Šesták 'v6ak'
Yes, I'm seeing the same thing. I have already notified the team directly about this.
It seems to have been fixed now. The dom0 updates have passed. The DomU Fedora updates have succeeded with updating the macros.qubes file, which is supposingly the workaround by Qubes team.
I now realize that we neglected to state, in the QSB, what the desired result from updating Fedora-based TemplateVMs and StandaloneVMs should be. I presume this is it:
Yes this seems right (in subsequent runs, the
/usr/lib/rpm/macros.d/macros.qubes state will not have "New file"
comment, but will still have "Result: True").
Below you should also see a summary with "Failed: 0".
Best Regards,
Marek Marczykowski-Górecki
Invisible Things Lab
Maybe it should be stated explicitly that Qubes update tool or qubesctl is needed and just updating manually through vm or Qube Manager is not sufficient.
Btw, the workaround can also be confirmed by updating manually through vm or Qubes Manager, dnf will then state that GPG signature check is enforced globally.
