Hi!
I have a problem 8-(
After using Qubes OS after a longer break, I tried to install all updates. That worked for all template VMs except debian-11. Even when re-trying after all the rest was updated and the system rebooted, it won't work.
Even worse I can start a debian-11-based app VM, but I cannot launch any program there. Even "qvm-run debian-11 gnome-terminal" fails.
I have saved the lengthy protocol of the first attempt, however (attached).
It seems the problem was:
Unpacking thunderbird (1:91.12.0-1~deb11u1) over (1:91.8.0-1~deb11u1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-GfbHjN/38-thunderbird_1%3a91.12.0-1~deb11u1_amd64.deb (--unpack):
cannot copy extracted data for './usr/share/thunderbird/omni.ja' to '/usr/share/thunderbird/omni.ja.dpkg-new': failed to write (No space left on device)
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Note: It's not pool00 that is full. How can I recover from this?
(I'm still at Qubes OS 4.0. I wanted to install the last updates, then backup, then try upgrading to 4.1)
Regards,
Ulrich
debian11.log (58 KB)
