Trying to get my WLAN adapter into sys-net, I made a fatal mistake: The USB host added also has the boot device (and mouse) connected. Now as soon as sys-net starts (maybe even earlier) the PV for qubes becomes inaccessible.
Mounting the device in another Linux system, I tried to prevent the start of sys-net by renaming the systemd link for multi-user target, but that did not help. The kernel panics shortly after boot.
Before I had tried to find (and edit) the settings that cause the problem, but could not find them.
My idea was to prevent start of sys-net, then use the qubes manager to undo my bad setting.
Unfortunately I don't get that far.
On Tue, Dec 08, 2020 at 10:22:17PM +0000, 'awokd' via qubes-users wrote: > Ulrich Windl:
> Hi!
I wouldn't change too much in that file, just the absolute minimum.
To edit the xml file and remove the devices assigned to sys-net, look
for lines like <device backend-domain="dom0" id="xxxxxx"/> in the
sys-net section - delete those lines.
MAKE SURE you have a copy of that file somewhere safe before editing.
Then restart - sys-net should start but wont be stealing the usb
devices.
Thanks for the help. Actually I'm sending this from Qubes, so the fix was successful
Let me share some of my desperate attempts that all did not work. I'm telling you so you do not waste your time like I did.
* Editing /etc/libvirt/libxl/sys-net.xml did not help
* Trying to deactivate automatic start of sys-net via systemd did not work
* Editing the GRUB boot entry interactively allows you to specify "single" for single-user boot, but as long as the root user is disabled you end in a "cul de sac". I mounted the root LV from another system and set the root password to something (editing /etc/shadow).
* Trying the recovery option of the Installation media did not work (see attached image)
* There were some more boot menu choices that did not boot (I didn't understand what those are good for)
