I am trying to follow the instructions described at the following link: https://wiki.trezor.io/Qubes_OS
in order to install and use Trezor HW wallet on my qubes.
in my qubes i have 2 users, the normal one and a root user.
i have succeeded to run the first instructions part (dom0).
but i failed to run the sys-usb part, it says:
in sys-usb:
sudo vim /usr/local/etc/qubes-rpc/trezord-service
add this line:
socat - TCP:localhost:21325
but i couldnt find the path /usr/local/etc/qubes-rpc/ in sys-usb (in terminal), so i couldnt create the file and add the line into it, i tried both in the root and the normal user.
can you please help? i am new to qubes, sorry for any inconvenience.
