How to burn directory’s to an optical disc in Qubes OS 4.0.3 by using an application ?
Which application is recommended and how to install it ?
I have read this: https://www.qubes-os.org/doc/optical-discs/
Since you didn't specify, I'll assume you're talking about using a USB optical drive inside of a standard qube, which is the least problematic route. This sounds like a general Linux question, so you might be able to find some helpful existing answers by searching more generally. For example, if you want to do this in a Fedora qube, you might try searching for recommended disc burning software for Fedora in general. (Of course, there's nothing wrong with also asking here. Just pointing out an additional option.)
As for how to install it, most likely the standard way:
(Attachment OpenPGP_signature is missing)
