[qubes-users] HCL report on a Lenova system
Here is my HCL report.
Thanks for all the hard works.
Best,
Amir
Qubes-HCL-LENOVO-2325PB3-20220209-152438.yml (913 Bytes)
Thank you Amir for your R4.1 HCL report, which is [online](Hardware compatibility list (HCL) | Qubes OS) now.
/Sven
AmiR,
your report states a BIOS version `Heads v1.3.1`. I just pulled and build the current head revision of the heads project and that version is `heads-v0.2.0-1150`.
Did you build and flash Heads yourself? Can you shed light on the version number?
/Sven
No, actually I did not touch it at all. I am on a NitroPad X230 and recently they have provided an updated firmware for Qubes 4.1 (Firmware Update v1.4+ — Nitrokey Documentation). However, I did not upgrade to this new one yet. I am planing to do so sometime next week.
Thank you for the clarification. I have updated your report [1] to reflect this fact, which also explains the versioning difference. Excellent outcome!
/Sven
[1] Hardware compatibility list (HCL) | Qubes OS
Thanks and i will send you an update report as soon as I upgrade it.
