Installation instructions :
Please note that I’m using HEADS and not a normal BIOS
- Use ISO Qubes
- In the Heads menu, go to USB boot
- When booting to install, select “Install Qubes OS"
- Finish installation and boot into OS
Remarks
The only issue I’ve encountered is the WiFi killswitch :
If you deactivate the wifi/bluetooth before booting, sys-net will have an issue and won’t boot. It seems that it’s because of Dom0 recheking each time the PCI device. If you re-enable the wifi and reboot the laptop the wifi will work again without problems
The important things work:
-Wifi
-Sound (Even though, you have to manually change from Speaker/headphone librem EC’s fault, not QubesOS)
-HDMI
-USB
-Fedora 37
-Debian 11
-Whonix
-Gentoo Archlinux BlackArchlinux parrot kali Openbsd debian 12
Not tested:
-Bluetooth
-Microphone/Camera
Qubes-HCL-Purism-librem_14-20230514-182829.yml (834 Bytes)
