To contribute. <3 QubesOS works great with the 2 x E5-2650v2 and 64GbRAM
Disclaimer:
I use HVM Win64x7/10 for specific professionnal softwares, I have no
choice on it (and it's quite a shame)
If you planned (as me) using a DL360p G8 as Desktop computer, you need
to know it's REALLY REALLY NOISY+++ compare to other HP rackserver
series !!!
* Hard Drives:
\- boot and VM on: M\.2 Sata SSD 256Go on PCIe
\- data on: i420 1GB RAID 10 \- 4 x 1To
* Network adapter: HP 366FLR on FlexibleLOM, using Intel i350 igb driver
--> support PCI passthrough to sys-net OK
* 2nd Graphic adapter: Radeon 2400 HD on PCIe --> support GPU
passthrough to HVM Win64x7/10-Qubes OK
* Other peripherals on USB, use to do: 1st USB bus for sys-usb and 2nd
USB bus PCI passthrough to HVM Win64x7/10
Note:
just 2 PCIe and 1 FlexLOM ports in a DL360p G8, that's not a lot...
so before having the working HP366FLR Network adapter, I tried:
- HP331FLR on FlexLOM --> doesn't support PCI passthrough to sys-net
- HP530SFP+ on FlexLOM --> doesn't support PCI passthrough to sys-net
- PCIe riser (cryptomining hardwares):
\- \[1xPCIe\-x1\] to \[4xPCIe\-x1 \+ 1xPCIe\-x16\] with Graphics\-PCIe,
USB3-PCIe, SATA3-PCIe, Network-PCIe --> surprisingly works, but with
shitty transfert data rate
Qubes-HCL-HP-ProLiant_DL360p_Gen8-20210514-130041.yml (1.13 KB)
