Dear Qubes Users,
I have tried Qubes on my System.
Attached is the report for Hardware Compatibility List.
Regards,
Qubes Users
Qubes-HCL-Hewlett_Packard-HP_Pavilion_Notebook_-20201123-171313.yml (959 Bytes)
Dear Qubes Users,
Regards,
Qubes Users
May I know the procedure to add this report into hardware compatibility list ?
And whether it is qualified for the list ?
list ?
Thank you for your report!
Our HCL maintainer periodically collects all reports sent to this mailing list and submits them in a pull request to:
However, if you prefer, you can simply submit a PR there yourself.
That'll be up to our HCL maintainer to determine, but usually reports are accepted without any problems.
Thank you for your information.
Okay, I will let the HCL maintainer determine.
Thanks and Best Regards,
