Hey
I did a fresh install and updated everything what was possible over the ‘‘Qubes Update Widget’’.
After that i generated the HCL report over the terminal like it says on your website.
I’m a complete newbie to qubes but all i saw and heard from it was awesome! You are really doing important work here! Thanks to all of you
Best
Phil
Qubes-HCL-Dell_Inc_-Latitude_3330-20210219-205102.yml (902 Bytes)
