> > > How to use disposables | Qubes OS
> > > states:
> > > > To do this [make a particular application open everything in
> > > > a
> > > > disposable VM], enable a service named app-dispvm.X in that
> > > > qube,
> > > > where X is the application ID.
> > > and invokes `app-dispvm.thunderbird` as an example.
> > > How would you do that for an application installes and run
> > > through
> > > flatpak?
> > Flatpak-installed applications still have an application ID,
> > which is
> > what gets passed to qubes.StartApp to launch the application.
> Thank you for your answer. Lengthy googling has dug up no answer to
> what an "application ID" actually is or how to look it up. Could
> you
> please help with that? Given a running program, how do I identify
> it?
It is the name of the .desktop file the application has within the
VM.
For Flatpak apps, I believe it will always be the ID of the flatpak
(the
reverse-DNS name).
Thank you.
I did the following:
1) in `dom0`:
qvm-service task-privcom app-dispvm.org.gnome.Evolution on
2) restart task-privcom
This does not work: neither *.pdf, nor *.jpeg, etc. get opened in a
dispvm when opening (double clicking) from within Evolution ...
Further pointers?
Sincerely, Joh
