Dear Qubes Community,
Fedora 31 has reached EOL (end-of-life [1]). If you have not already done so, we strongly recommend upgrading your Fedora 31 TemplateVMs and StandaloneVMs to Fedora 32 immediately. We provide step-by-step upgrade instructions for upgrading Fedora TemplateVMs [2]. For a complete list of TemplateVM versions supported for your specific version of Qubes, see the list of supported TemplateVM versions [3].
We also provide a fresh Fedora 32 TemplateVM package through the official Qubes repositories, which you can install in dom0 by following the standard installation instructions [4].
After upgrading your TemplateVMs, please remember to switch all qubes that were using the old template to use the new one [5].
Please note that no user action is required regarding the OS version in dom0. For details, please see our note on dom0 and EOL [6].
[1] https://fedoraproject.org/wiki/End_of_life
[2] https://www.qubes-os.org/doc/template/fedora/upgrade/
[3] https://www.qubes-os.org/doc/supported-versions/#templatevms
[4] https://www.qubes-os.org/doc/templates/fedora/#installing
[5] https://www.qubes-os.org/doc/templates/#switching
[6] https://www.qubes-os.org/doc/supported-versions/#note-on-dom0-and-eol
