Install instructions:
Use at least Qubes R4.0.4 iso to install, as you will need the kernel 5.4 to to recognise PERC modules.
Before install, you must disable Bios → “Processor settings” → “x2APIC Mode”. Otherwise it won’t install.
To setup onboard network card “Broadcom Limited NetXtreme BCM5720 Gigabit Ethernet PCIe” :
- Remember and delete the entries in “Qubes manager” → sys-net → “Qube settings” → “Devices” → “Selected”
- In dom0 terminal:
Do the following for all the entries in step 1. Eg.: for PCIe device 64:00.0 this will be:
$ qvm-pci attach --persistent --option permissive=true sys-net dom0:64_00.0
(note the underscore in PCIe address)
Remarks:
All seem to work fine. Except I find disk writes a bit slow.
Cheers
Qubes-HCL-Dell_Inc_-PowerEdge_R7525-20210311-092229.yml (1.21 KB)
