Hey guys, I’ve tried rigorously to install pidgin package and after getting all the dependencies and errors worked out it finally installed. But then upon checking /usr/bin/ it doesn’t appear. Has anyone got pidgin successfully working inside whonix VM?
Furthermore, how can one go about adding a shortcut? I’ve created a .desktop file and then used these instructions but am not sure what the custom menu entry would look like inside the anon-whonix-vm.menu file would look like…
Pidgin
pidgin.desktop
//Do I put the whole path to the .desktop file?
TheCrispyToast:
Furthermore, how can one go about adding a shortcut? I've created a
<http://qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/doc/managing-appvm-shortcuts/>but
anon-whonix-vm.menu file would look like...
<Menu>
<Name>Pidgin</Name>
<Include>
<Filename>pidgin.desktop</Filename>
</Include>
</Menu>
Not sure about Pidgen in particular, but the above shortcut looks alright. Don't need the full path, but verify it's there inside the AppVM.
