The problem comes long ago, I found a solution by setting the update VM on dom0 to sys whonix. With update VM sys firewall I got "/usr/liv/qubes-download-dom0-updates.sh: No such file or directory".
With update VM sys whonix it worked well. But now it can not reach any update server (also changed some tor ips, but without any effect).
I did nothing on dom0 and nothing of sys firewall or sys whonix. Just updated them in regular way.
Sounds like the template sys-firewall is using is not right. Try switching it from Fedora to Debian or vice-versa and see if it works then. If so, reinstall the broken template, but be aware you'll lose any customizations to it.
