I’d like to add a network drive (Buffalo NAS)to my Qubes 4.0 system to back up my Qubes. Is it possible?
William Fisher:
I'd like to add a network drive (Buffalo NAS)to my Qubes 4.0 system to back
Yes. Attach it to a VM with qvm-block, then run the Qubes Backup utility. More detail in here under Creating a backup: How to back up, restore, and migrate | Qubes OS .
I stil can’t figure out how to mount the NAS on my local LAN as local storage of my qubes (4.0) back-ups. How do I get Qubes to See the NAS drive?
How can I connect a network drive to an app VM?
Bill
or “Mount”
This is not Qubes specific. Please consult the documentation for the distribution your AppVM's are based on. For example, if your AppVM's are using a Fedora template, consult Fedora's documentation.
William Fisher:
or "Mount"
Bill
I stil can't figure out how to mount the NAS on my local LAN as local
storage of my qubes (4.0) back-ups. How do I get Qubes to See the NASdrive?
William Fisher:
system to back
<https://www.qubes-os.org/doc/how-to-back-up-restore-and-migrate/> .--
- don't top post
Mailing list etiquette:
- trim quoted reply to only relevant portions
- when possible, copy and paste text instead of screenshotsHi William,
Dom0 has no network connection, so it isn't possible to connect
network storage to it.When the Qubes backup process is run, it asks which VM should the
backup be sent to.I have a VM called Backup in which I mount a shared folder from
my NAS device. The backup process works fine using this. And I
know that restores from the shared NAS folder work OK too, because
I test that occasionally.Good luck,
Mike.
Assumed you had a USB connection to your NAS, sorry. Qvm-block won't work for network storage.
