Hey I tried updating dom and perhaps I just should not have. Cause it’s still updating hours later! What is the solution?
Cancel the update and try it manually in a terminal in dom0 with
sudo qubes-dom0-update
or
sudo dnf update
in the fedora template
Is this the first time you use the system?
I’d go for this approach as well. If you find what was making it slow, please paste it here on the forum. You can copy text from dom0 with these instructions.
