I’ve been using Qubes OS since last fall. Generally, when Qubes Update finishes updating some templates, it gives a checklist of qubes it will restart, which are based on those templates. Starting in the last month or so, I’ve noticed that it doesn’t actually restart those qubes. I have to go into Qube Manager and manually restart them myself.
Has anyone else noticed this behavior? Is there some configuration I can fix so this feature of Qubes Update works the way it used to?
It’s fixed. Wait for qubes-desktop-linux-manager to get updated.
opened 06:02PM - 10 Jul 25 UTC
closed 10:38AM - 17 Jul 25 UTC
C: Qubes GUI tools
P: default
diagnosed
C: updates
affects-4.2
### Qubes OS release
Qubes OS 4.2.4
### Brief summary
root# qubes-update-… gui
Exception in thread Thread-7 (perform_restart):
File "/usr/lib64/python3.11/threading.py", line 1045, in _bootstrap_inner
self.run()
File "/usr/lib64/python3.11/threading.py", line 982, in run
self._target(*self._args, **self._kwargs)
File "/usr/lib/python3.11/site-packages/qui/updater/summary_page.py", line 297, in perform_restart
self.shutdown_domains(tmpls_to_shutdown)
File "/usr/lib/python3.11/site-packages/qui/updater/summary_page.py", line 320, in shutdown_domains
loop = asyncio.get_event_loop()
File "/usr/lib64/python3.11/asyncio/events.py", line 677, in get_event_loop
raise RuntimeError('There is no current event loop in thread %r.'
RuntimeError: There is no current event loop in thread 'Thread-7 (perform_restart)'.
### Steps to reproduce
1. run `qubes-update-gui` from dom0 terminal
2. update qubes
3. select qubes with updated templates and click the next button
### Expected behavior
The qubes should get restarted.
### Actual behavior
The updater crashes with the above shown terminal output.
### Additional information
_No response_
Thank you! So, I presume this update will or has appeared in an update of dom0?
Forogot to mention: You could try the fix. It’s three lines of code, some comment and added indentation in /usr/lib/python3.11/site-packages/qui/updater/summary_page.py
main ← marmarta:bugfixglib
As behavior of asyncio.get_event_loop changes between python
3.10 and 3.12, and … GLib asyncio integration is still
experimental, some combinations of python/glib
versions could fail at running a new event loop.
This workaround should handle all combinations.
barto
July 24, 2025, 8:33am
6
As the commit was performend on July 16 and it takes two weeks to get the packages to the “stable” repo(s), ETA is “not sooner than July 30”
The pull request merged in the main branch, so for Qubes OS 4.3, not (yet) backported to 4.2
