Hi. Is repo broken or iam doing something wrong?
pinging @fepitre
[doom@dom0 ~]$ install --refresh
Using sys-firewall as UpdateVM to download updates for Dom0; this may take some time...
Fedora 25 - x86_64 - Updates 9.9 kB/s | 5.0 kB 00:00
Fedora 25 - x86_64 11 kB/s | 5.3 kB 00:00
Qubes OS Contrib Repository for dom0 (updates) 12 kB/s | 3.0 kB 00:00
Qubes OS Contrib Repository for dom0 (updates-t 13 kB/s | 3.0 kB 00:00
Qubes Dom0 Repository (updates) 11 kB/s | 2.7 kB 00:00
Qubes Dom0 Repository (updates-testing) 11 kB/s | 2.9 kB 00:00
Qubes Templates repository 11 kB/s | 2.7 kB 00:00
Dependencies resolved.
Nothing to do.
Complete!
Qubes OS Repository for Dom0 23 MB/s | 26 kB 00:00
[doom@dom0 ~]$ search i3-gaps
Last metadata expiration check: 0:01:02 ago on Tue Oct 27 01:00:27 2020.
======================== Name Exactly Matched: i3-gaps =========================
i3-gaps.x86_64 : i3 with more features
======================= Name & Summary Matched: i3-gaps ========================
i3-gaps-debuginfo.x86_64 : Debug information for package i3-gaps
i3-gaps-devel.x86_64 : Development files for i3-gaps
i3-gaps-devel-doc.noarch : Documentation for the development files of i3-gaps
i3-gaps-doc.noarch : Documentation for i3-gaps
No packages downloaded
[doom@dom0 ~]$ install i3-gaps
Last metadata expiration check: 0:01:16 ago on Tue Oct 27 01:00:27 2020.
Package Arch Version Repository Size
Installing:
i3-gaps x86_64 1000:4.18.1-1.fc25 qubes-contrib-dom0-r4.0-current-testing 325 k
Installing dependencies:
libconfuse x86_64 3.0-1.fc25 fedora 176 k
xorg-x11-xbitmaps noarch 1.1.1-9.fc24 fedora 41 k
Installing weak dependencies:
i3lock x86_64 2.9.1-1.fc25 updates 31 k
i3status x86_64 2.11-1.fc25 updates 57 k
pulseaudio-utils x86_64 10.0-2.fc25 updates 72 k
rxvt-unicode x86_64 9.22-2.fc25 fedora 746 k
xorg-x11-apps x86_64 7.7-15.fc24 fedora 320 k
Removing dependent packages:
i3 x86_64 1000:4.16-9.fc25 @System 911 k
Transaction Summary
Install 8 Packages
Remove 1 Package
Total download size: 1.7 M
DNF will only download packages for the transaction.
Downloading Packages:
(1/8): i3lock-2.9.1-1.fc25.x86_64.rpm 198 kB/s | 31 kB 00:00
(2/8): pulseaudio-utils-10.0-2.fc25.x86_64.rpm 374 kB/s | 72 kB 00:00
(3/8): i3status-2.11-1.fc25.x86_64.rpm 281 kB/s | 57 kB 00:00
(4/8): libconfuse-3.0-1.fc25.x86_64.rpm 364 kB/s | 176 kB 00:00
(5/8): xorg-x11-apps-7.7-15.fc24.x86_64.rpm 523 kB/s | 320 kB 00:00
(6/8): xorg-x11-xbitmaps-1.1.1-9.fc24.noarch.rp 223 kB/s | 41 kB 00:00
(7/8): rxvt-unicode-9.22-2.fc25.x86_64.rpm 961 kB/s | 746 kB 00:00
(8/8): i3-gaps-4.18.1-1.fc25.x86_64.rpm 504 kB/s | 325 kB 00:00
Total 847 kB/s | 1.7 MB 00:02
warning: /var/lib/qubes/dom0-updates/var/cache/yum/x86_64/4.0/qubes-contrib-dom0-r4.0-current-testing-8801c9554e16b90e/packages/i3-gaps-4.18.1-1.fc25.x86_64.rpm: Header V4 RSA/SHA256 Signature, key ID d0941e87: NOKEY
Qubes OS Contrib Repository for dom0 (updates-t 0.0 B/s | 0 B 00:00
Curl error (37): Couldn't read a file:// file for file:///etc/pki/rpm-gpg/RPM-GPG-KEY-qubes-4-contrib-fedora [Couldn't open file /etc/pki/rpm-gpg/RPM-GPG-KEY-qubes-4-contrib-fedora]
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
[doom@dom0 ~]$ ls -l /etc/pki/rpm-gpg/
total 68
-rw-r--r-- 1 root root 1670 Jan 13 2020 RPM-GPG-KEY-fedora-25-primary
-rw-r--r-- 1 root root 2364 Jan 13 2020 RPM-GPG-KEY-qubes-3.1-primary
-rw-r--r-- 1 root root 1657 Jan 13 2020 RPM-GPG-KEY-qubes-3.1-templates-community
-rw-r--r-- 1 root root 1641 Jan 13 2020 RPM-GPG-KEY-qubes-3.1-unstable
-rw-r--r-- 1 root root 2364 Jan 13 2020 RPM-GPG-KEY-qubes-3.2-primary
-rw-r--r-- 1 root root 1657 Jan 13 2020 RPM-GPG-KEY-qubes-3.2-templates-community
-rw-r--r-- 1 root root 1641 Jan 13 2020 RPM-GPG-KEY-qubes-3.2-unstable
-rw-r--r-- 1 root root 2364 Jan 13 2020 RPM-GPG-KEY-qubes-3-primary
-rw-r--r-- 1 root root 1657 Jan 13 2020 RPM-GPG-KEY-qubes-3-templates-community
-rw-r--r-- 1 root root 1641 Jan 13 2020 RPM-GPG-KEY-qubes-3-unstable
lrwxrwxrwx 1 root root 34 May 25 03:59 RPM-GPG-KEY-qubes-4.0-contrib-fedora -> RPM-GPG-KEY-qubes-4-contrib-fedora
-rw-r--r-- 1 root root 2346 Jan 13 2020 RPM-GPG-KEY-qubes-4.0-primary
-rw-r--r-- 1 root root 1657 Jan 13 2020 RPM-GPG-KEY-qubes-4.0-templates-community
-rw-r--r-- 1 root root 1641 Jan 13 2020 RPM-GPG-KEY-qubes-4.0-unstable
-rw-r--r-- 1 root root 1769 May 25 03:59 RPM-GPG-KEY-qubes-4-contrib-fedora
-rw-r--r-- 1 root root 2346 Jan 13 2020 RPM-GPG-KEY-qubes-4-primary
-rw-r--r-- 1 root root 1657 Jan 13 2020 RPM-GPG-KEY-qubes-4-templates-community
-rw-r--r-- 1 root root 1641 Jan 13 2020 RPM-GPG-KEY-qubes-4-unstable
