Hello people, first of all, sorry for my bad english, its not my native language…
Ok, i have a Mac Pro 5,1 2010-2012, and i want to use qubes, but every time i click on any option to start installation, i got a black screen.
My Specs are:
GPU RX 570 8gb
Ram 4x16gb 1333mhz (64gb total)
CPU Xeon 6 core six threads
Storage:
120GB ssd
500GB hd
2x1TB hd
512GB nvme
When the Qubes OS installation starts, following the GRUB (?) selection, it is not unusual to have a long period where the screen is black. Eventually, the graphical installer starts.
Sometimes the system will freeze with a black screen following installation and a reboot. My Lenovo laptop did that. When the system is turned off by holding the power button down, and then the system is turned back on, you might be surprised to find the system working.
Did I answer your question?
Your system is very powerful and more than enough to run Qubes OS. VT-X and VT-D must both be enabled. Your system has 4 x 8 GB = 32 GB, not 64 GB (!)
Sorry for the basic math error, i didnt noticed haha, but no, unfurtumatly i cant boot the installer, the black screen still happaning I tried all the grub options and none of them worked
We know that you can definitely get to the GRUB menu, which is a good start.
Once you are there, you need to select your option (do NOT press Enter), and then press E. This will allow you edit the configuration.
single should work, but if you can, also try and remove any instances where you see the word quiet as well. That will allow us to see what’s happening.
This will likely cause issues during the initial setup on first boot (when it’s setting up sys-net), but it shouldn’t prevent the ISO from booting. I’d be surprised if it was causing the issue.
Oh how I wish Apple hardware had a configurable BIOS
@EdZiin1007, try adding the following to the GRUB kernel parameters:
nomodeset
radeon.modeset=0
I have a feeling Linux is trying to interface with a Radeon card as if it were a modern RX card…
I tried all of the kernel parameters, and nothing, same black screen, tried a old Nvidia gt 610 2GB, removed my pci nvme adaptor, my pci usb adaptor and nothing, already tried to blacklist the wifi card…
That’s relevant. It means that it’s not just the display, but the entire machine.
Unfortunately, this sounds a lot like what I encountered with my Apple hardware from around the same age as yours:
The issue is that those Xeon CPUs in your hardware aren’t 1-to-1 with what you’d find in other PC hardware. They were made specially for Apple, and could potentially have some key functions missing (Apple did this a lot with their hardware), that the Qubes ISO is expecting to find, hence the errors.
Give me a second. I’m checking up on how to launch the Qubes ISO in text-mode only…
