Qubes OS updates Weekly Review - Y2025-W31
Introduction
qubes-core-agent-4.2.43-1.fc41.x86_64.rpm
qubes-core-agent-4.2.43-1.fc42.x86_64.rpm
qubes-core-agent-caja-4.2.43-1.fc41.x86_64.rpm
qubes-core-agent-caja-4.2.43-1.fc42.x86_64.rpm
qubes-core-agent-caja_4.2.43-1+deb12u1_amd64.deb
qubes-core-agent-caja_4.2.43-1+deb13u1_amd64.deb
qubes-core-agent-caja_4.2.43-1+jammy1_amd64.deb
qubes-core-agent-caja_4.2.43-1+noble1_amd64.deb
qubes-core-agent-dbgsym_4.2.43-1+deb12u1_amd64.deb
qubes-core-agent-dbgsym_4.2.43-1+deb13u1_amd64.deb
qubes-core-agent-dom0-updates-4.2.43-1.fc41.noarch.rpm
qubes-core-agent-dom0-updates-4.2.43-1.fc42.noarch.rpm
qubes-core-agent-dom0-updates_4.2.43-1+deb12u1_amd64.deb
qubes-core-agent-dom0-updates_4.2.43-1+deb13u1_amd64.deb
qubes-core-agent-dom0-updates_4.2.43-1+jammy1_amd64.deb
qubes-core-agent-dom0-updates_4.2.43-1+noble1_amd64.deb
qubes-core-agent-nautilus-4.2.43-1.fc41.x86_64.rpm
qubes-core-agent-nautilus-4.2.43-1.fc42.x86_64.rpm
qubes-core-agent-nautilus_4.2.43-1+deb12u1_amd64.deb
qubes-core-agent-nautilus_4.2.43-1+deb13u1_amd64.deb
qubes-core-agent-nautilus_4.2.43-1+jammy1_amd64.deb
qubes-core-agent-nautilus_4.2.43-1+noble1_amd64.deb
qubes-core-agent-network-manager-4.2.43-1.fc41.noarch.rpm
qubes-core-agent-network-manager-4.2.43-1.fc42.noarch.rpm
qubes-core-agent-network-manager_4.2.43-1+deb12u1_amd64.deb
qubes-core-agent-network-manager_4.2.43-1+deb13u1_amd64.deb
qubes-core-agent-network-manager_4.2.43-1+jammy1_amd64.deb
qubes-core-agent-network-manager_4.2.43-1+noble1_amd64.deb
qubes-core-agent-networking-4.2.43-1.fc41.noarch.rpm
qubes-core-agent-networking-4.2.43-1.fc42.noarch.rpm
qubes-core-agent-networking_4.2.43-1+deb12u1_amd64.deb
qubes-core-agent-networking_4.2.43-1+deb13u1_amd64.deb
qubes-core-agent-networking_4.2.43-1+jammy1_amd64.deb
qubes-core-agent-networking_4.2.43-1+noble1_amd64.deb
qubes-core-agent-passwordless-root-4.2.43-1.fc41.noarch.rpm
qubes-core-agent-passwordless-root-4.2.43-1.fc42.noarch.rpm
qubes-core-agent-passwordless-root_4.2.43-1+deb12u1_amd64.deb
qubes-core-agent-passwordless-root_4.2.43-1+deb13u1_amd64.deb
qubes-core-agent-passwordless-root_4.2.43-1+jammy1_amd64.deb
qubes-core-agent-passwordless-root_4.2.43-1+noble1_amd64.deb
qubes-core-agent-selinux-4.2.43-1.fc41.noarch.rpm
qubes-core-agent-selinux-4.2.43-1.fc42.noarch.rpm
qubes-core-agent-systemd-4.2.43-1.fc41.x86_64.rpm
qubes-core-agent-systemd-4.2.43-1.fc42.x86_64.rpm
qubes-core-agent-thunar-4.2.43-1.fc41.x86_64.rpm
qubes-core-agent-thunar-4.2.43-1.fc42.x86_64.rpm
qubes-core-agent-thunar_4.2.43-1+deb12u1_amd64.deb
qubes-core-agent-thunar_4.2.43-1+deb13u1_amd64.deb
qubes-core-agent-thunar_4.2.43-1+jammy1_amd64.deb
qubes-core-agent-thunar_4.2.43-1+noble1_amd64.deb
qubes-core-agent_4.2.43-1+deb12u1_amd64.deb
qubes-core-agent_4.2.43-1+deb13u1_amd64.deb
qubes-core-agent_4.2.43-1+jammy1_amd64.deb
qubes-core-agent_4.2.43-1+noble1_amd64.deb
qubes-vm-core-4.2.43-1-x86_64.pkg.tar.zst
qubes-vm-keyring-4.2.43-1-x86_64.pkg.tar.zst
qubes-vm-networking-4.2.43-1-x86_64.pkg.tar.zst
qubes-vm-passwordless-root-4.2.43-1-x86_64.pkg.tar.zst
qubes-windows-tools-4.2.1-1.fc41.noarch.rpm
salt-3007.6-1.fc41.noarch.rpm
salt-3007.6-2.fc41.noarch.rpm
salt-api-3007.6-1.fc41.noarch.rpm
salt-api-3007.6-2.fc41.noarch.rpm
salt-api_3007.6-2+deb12u1_all.deb
salt-api_3007.6-2+deb13u1_all.deb
salt-api_3007.6-2+noble1_all.deb
salt-cloud-3007.6-1.fc41.noarch.rpm
salt-cloud-3007.6-2.fc41.noarch.rpm
salt-cloud_3007.6-2+deb12u1_all.deb
salt-cloud_3007.6-2+deb13u1_all.deb
salt-cloud_3007.6-2+noble1_all.deb
salt-common_3007.6-2+deb12u1_all.deb
salt-common_3007.6-2+deb13u1_all.deb
salt-common_3007.6-2+noble1_all.deb
salt-doc_3007.6-2+deb12u1_all.deb
salt-doc_3007.6-2+deb13u1_all.deb
salt-doc_3007.6-2+noble1_all.deb
salt-master-3007.6-1.fc41.noarch.rpm
salt-master-3007.6-2.fc41.noarch.rpm
salt-master_3007.6-2+deb12u1_all.deb
salt-master_3007.6-2+deb13u1_all.deb
salt-master_3007.6-2+noble1_all.deb
salt-minion-3007.6-1.fc41.noarch.rpm
salt-minion-3007.6-2.fc41.noarch.rpm
salt-minion_3007.6-2+deb12u1_all.deb
salt-minion_3007.6-2+deb13u1_all.deb
salt-minion_3007.6-2+noble1_all.deb
salt-proxy_3007.6-2+deb12u1_all.deb
salt-proxy_3007.6-2+deb13u1_all.deb
salt-proxy_3007.6-2+noble1_all.deb
salt-ssh-3007.6-1.fc41.noarch.rpm
salt-ssh-3007.6-2.fc41.noarch.rpm
salt-ssh_3007.6-2+deb12u1_all.deb
salt-ssh_3007.6-2+deb13u1_all.deb
salt-ssh_3007.6-2+noble1_all.deb
salt-syndic-3007.6-1.fc41.noarch.rpm
salt-syndic-3007.6-2.fc41.noarch.rpm
salt-syndic_3007.6-2+deb12u1_all.deb
salt-syndic_3007.6-2+deb13u1_all.deb
salt-syndic_3007.6-2+noble1_all.deb
xen-utils-guest_5.0.3-1+jammy1_amd64.deb
xen-utils-guest_5.0.4-1+deb12u1_amd64.deb
xen-utils-guest_5.0.4-1+deb13u1_amd64.deb
xen-utils-guest_5.0.4-1+jammy1_amd64.deb
xen-utils-guest_5.0.4-1+noble1_amd64.deb
Highlights
- Debian 13 Trixie related patches.
Details
qubes-template-debian-13-minimal 4.3.0-202508032011 (r4.3)
qubes-template-debian-13 4.3.0-202508032011 (r4.3)
qubes-template-debian-13-xfce 4.3.0-202508032011 (r4.3)
A fresh set of Debian 13 templates. These should include fixes for networking onsys-firewalland missing Thunar shortcut in AppMenu. Also fix for salt which was discussed last week. -
salt v3007.6-2 (r4.3)
salt v3007.6-1 (r4.3)
Salt version upgrade with all of the latest patches. The highlight is Debian 13 support. -
installer-qubes-os-windows-tools v4.2.1-1 (r4.3)
installer-qubes-os-windows-tools v4.2.0-1 (r4.3)
. A long list of almost 100 commits and 2000 lines of changes. Most are older commits.
. The most new commits are to automatically accept test signed drivers. -
gui-agent-windows v4.2.2 (r4.3)
. Fix for a bug to allow Windows qubes to be used with a dedicatedsys-gui*. -
vmm-xen-guest v5.0.4-1 (r4.3)
vmm-xen-guest v5.0.4-1 (r4.2)
vmm-xen-guest v5.0.3-1 (r4.2)
Fix for Debian 13 trixie networking issue assys-firewall -
core-agent-linux v4.2.43 (r4.2)
. Backporting of patches to r4.2
. DNF5 related fixes.
. Memory ballooning related patches.
. Missing dependencies related fixes.
. Archlinux related improvements.
. Other minor cleanups.
Epilogue
A new targets-4.3 label was created on Qubes OS issue Github repo and All new features and improvements which would most probably land in Qubes r4.3 RC1 are marked with that label. There are currently 45 finalized and closed items and 19 pending ones. Announcements for the new RC are being drafted at the moment.
