Contents of https://yum.qubes-os.org/r4.2/templates-community/rpm/ :
qubes-template-archlinux-4.2.0-202309141139.noa..> 14-Sep-2023 12:16 671690728
qubes-template-kicksecure-17-4.2.0-202505131900..> 13-May-2025 19:29 670542268
qubes-template-whonix-gateway-17-4.2.0-20230713..> 13-Jul-2023 14:01 457070006
qubes-template-whonix-gateway-17-4.2.0-20231006..> 06-Oct-2023 06:35 467576539
qubes-template-whonix-gateway-17-4.2.0-20231222..> 22-Dec-2023 19:36 466912449
qubes-template-whonix-gateway-17-4.2.0-20240312..> 12-Mar-2024 16:27 465681098
qubes-template-whonix-gateway-17-4.2.0-20240620..> 20-Jun-2024 17:03 464197357
qubes-template-whonix-gateway-17-4.2.0-20241107..> 07-Nov-2024 18:56 511867640
qubes-template-whonix-gateway-17-4.2.0-20250514..> 14-May-2025 10:13 500407640
qubes-template-whonix-workstation-17-4.2.0-2023..> 13-Jul-2023 14:41 787487638
qubes-template-whonix-workstation-17-4.2.0-2023..> 06-Oct-2023 07:13 789507228
qubes-template-whonix-workstation-17-4.2.0-2023..> 22-Dec-2023 20:35 794838281
qubes-template-whonix-workstation-17-4.2.0-2024..> 12-Mar-2024 17:12 799164433
qubes-template-whonix-workstation-17-4.2.0-2024..> 20-Jun-2024 17:57 801976886
qubes-template-whonix-workstation-17-4.2.0-2024..> 07-Nov-2024 16:49 860214784
qubes-template-whonix-workstation-17-4.2.0-2025..> 14-May-2025 10:58 825602630
Contents of http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.2/templates-community/rpm/ :
Shouldn’t the contents be exactly the same? The onion repo is missing a few builds of the Whonix templates including the most recent, and missing the new Kicksecure template entirely, placing it at least two weeks out of date.
I think this means that users can’t install new community templates over Tor if they’re using the more privacy-hygenic onion address. [*]
Note: https://yum.qubes-os.org/r4.2/templates-itl/rpm/ and http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.2/templates-itl/rpm/ are proper mirrors, it’s only the community repo that is out of date.
I can open an issue for this- just wanting to verify my understanding is right first.
/etc/qubes/repo-templates/qubes-templates.repo:
baseurl = http://yum.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r$releasever/templates-community
