Can I load qubes os on an encrypted usb stick? iStorage diskAshur Pro2 SSD 128GB or datashur pro 2, will make it safer and best or does it make no difference to a normal usb stick?
Hi.
If You haven’t the idea of disable software encryption on qubes volume pool, I think it can only slow down drive performance - imho.
Cheers,
M.
It makes no difference in my experience.
