I am re-posting this because my original post in “Help, I think I’ve been hacked” garnered only 7 views and I see a post, created after mine, unrelated to QubesOS (possibly by a troll) has more views.
I have a @novacustom NV41PZ laptop. I don’t have wifi/bluetooth chip in the laptop. I connect to internet using ethernet cable.
The laptop became unresponsive twice now. The first time when I was creating podman containers and was pulling packages to create the containers. Second time when I was running qubes-update-gui. Both times, the laptop became responsive after I disconnected the laptop from internet by removing the ethernet cable. There was some electronic noise (like when you start playing a cd or dvd) after I disconnect the ethernet cable and before the laptop unfroze.
I ran journalctl in dom0 and did not see any error message when the laptop was unresponsive. I do see a frequent core dump from xss-lock process which might be unrelated.
Below are the logs from the update process during which the laptop froze. I disconnected the ethernet cable somewhere in the middle of the process. Notice the big break after 14:02:57. Usually the update process completes immediately after it prints the summary messages. This time the update process ran for 90+ seconds before printing the message Remove /run/qubes-update/
Has anyone encountered similar issues? Where should I look to find the root cause of this issue?
2025-02-22 13:59:35,166 Running update agent for tmpl-browser
2025-02-22 13:59:35,177 Transferring files to destination qube: tmpl-browser
2025-02-22 13:59:40,643 The agent is starting the task in qube: tmpl-browser
2025-02-22 13:59:40,838 [Agent] Failed to load apt with progress bar. Use apt cli.
2025-02-22 14:02:57,143 [Agent] agent out: Installed packages:
2025-02-22 14:02:57,151 [Agent] agent out: None
2025-02-22 14:02:57,152 [Agent] agent out: Updated packages:
2025-02-22 14:02:57,152 [Agent] agent out: librewolf 135.0-1 -> 135.0.1-1
2025-02-22 14:02:57,152 [Agent] agent out: Removed packages:
2025-02-22 14:02:57,152 [Agent] agent out: None
2025-02-22 14:04:29,085 Remove /run/qubes-update/
2025-02-22 14:04:29,159 Shutdown tmpl-browser
2025-02-22 14:04:29,169 agent exit code: 0
