It is possible make QubesOS for ARM version such as Raspberry Pi CM4, CM5 and others?
It is technically/theoretically possible to run Xen on ARM, and if you try to search the forums (magnifier up right) you’ll find that many have thought about it (ARM, that is). But it’s pretty certain that anything Raspberry-like is too weak in terms of compute and RAM, to be usable for multiple VMs.
Thank you for the explanation.
A modern raspberry pi can reach up to 16GB ram. While it is true that it will not have the computing power of a real pc it could still be useful.
What about a macbook m2 pro with the asasi linux kernel?
No ARM is no ARM.
