I used Qubes OS for awhile, but eventually decided to move to Fedora. Right now, I’m trying to extract a file from my Qubes OS backup. I’m using the instructions here:
I was able to go through steps 1-6 without any issues.
When I execute step 7:
[user@restore vm1]$ sudo mkdir /mnt/img
[user@restore vm1]$ sudo mount -o loop vm1/private.img /mnt/img/
I get an error message, and learn more from the dmesg command:
dmesg | tail:
[379210.165574] loop11: detected capacity change from 0 to 4962553
[379210.166889] EXT4-fs (loop11): bad geometry: block count 52428800 exceeds size of device (620319 blocks
I didn’t quite understand this and thought it was a memory issue. I copied the “vm1” directory to my main Fedora drive where there’s tons of memory, but I got the exact same error.
Some people online say that using “resize2fs” can help, but I don’t really understand exactly how I would apply that in my situation.
My “vm1” directory looks like this:
-rw-r–r–. 1 user user 2540827136 Sep 17 18:06 private.img
-rw-r–r–. 1 user user 104857728 Sep 17 18:04 private.img.000.enc
-rw-r–r–. 1 user user 104857728 Sep 17 18:04 private.img.001.enc
-rw-r–r–. 1 user user 104857728 Sep 17 18:04 private.img.002.enc
-rw-r–r–. 1 user user 104857728 Sep 17 18:06 private.img.379.enc
-rw-r–r–. 1 user user 7180041 Sep 17 18:06 private.img.380.enc
Any thoughts would be most welcome.
Thank you.
