balko
September 8, 2023, 3:07pm
21
@solene thank you, I appreciate your work.
solene:
xfce panel: red qube
solene:
alt+tab: red qube
You mean cube, right? So, I think the bug affects R4.2.
If you try fedora-37 my guess will be you will have proper icon in these 2 cases. If you have time please check it, too. Thanks.
balko
September 8, 2023, 3:19pm
23
DVM:
The answer is here:
No, I meant cube, not qube. This one: Cube - Wikipedia
solene
September 8, 2023, 3:30pm
24
oh yeah, I’m getting confused. Qubes OS’s cube icon
edit: same cubic icon in the virtual desktops windows list
DVM
September 8, 2023, 3:31pm
25
My bad, I thought you were talking about VMs.
resulin
September 8, 2023, 4:52pm
26
balko:
It says: PipeWire support (#6358).
But the issue is open and the purposes of commits are not clear, some of them on contrary disable pipewire-related stuff. It is not obvious what is the current situation with pipewire and pulseaudio in the R4.2.
Is there any documentation about the current situation?
What should user use in dom0 and what in templates in R4.2?
If pipewire then does it have problems with sys-audio and audio qube approach? Or should user still stick to pulseaudio manually solving the packaging conflicts as it is in R4.1?
If pipewire in dom0, than will it work with existing user’s templates (e.g. migrated from backup) that use pulseaudio?
I had the same concern in the previous thread: Qubes OS 4.2.0-rc2 is available for testing - #19 by resulin
balko
September 9, 2023, 5:35am
27
balko:
The ticket Pipewire audio support · Issue #6358 · QubesOS/qubes-issues · GitHub was not closed because the Qubes developers forgot to do it.
The answer by @Demi about this:
I am not sure what the documentation status is.
PipeWire in dom0 is not officially supported. Audio playback and recording are known to work, but features such as sound volume save & restore don’t.
PipeWire in sys-audio and in qubes that connect to sys-audio is fully supported, at least to the extent that sys-audio is supported at all.
