Qubes not working for no reason
I honestly can only give this little bit of information
yesterday I turned my laptop on and I get to the Qubes disk password and it doesn’t take my password then. then after a certain amount of types of denying me I get the this ternmal and get the message that my disk is not found.
I exit out the ternmal and get the message I should regenerate my initramfs files
I really dont know what s going on…
EDIT: I restarted my computer to see the message when it first went in the emergency shell is says
/dev/mapper/qubes_dom0-root does not exist
/dev/qubes_dom0/root does not exist
/dev/qubes_dom0/swap does not exist
Where did they go?!?!
PSS. Im just assuming here but I think is a kernel panic issue
one of related problem:
is your password long
what does you mean
is this emergency dracut shell ? sometimes it only lvs not active and you need to mount it manually or you disk is not decrypted, then you need to manual decrypt and manual mount.
