On the hardware requirements it says there the following:
Note: Qubes OS is not meant to be installed inside a virtual machine as a guest hypervisor. In other words, nested virtualization is not supported. In order for a strict compartmentalization to be enforced, Qubes OS needs to be able to manage the hardware directly.
Read more:
You may want to try it by installing it on an external disk and that way it won’t interfered with your current windows installation.
