barto
July 8, 2024, 3:24pm
1
I have a question which bothered me for some time, and I really tried to find the answer by reading the documentation and cloning some git repos (at least for qubes-core and qubes-admin).
The question is: where are the (nft) interface groups defined ? for example, group 9 seems to be “VPN interfaces”, and group 2 is used in rules like:
chain prerouting {
type filter hook prerouting priority raw; policy accept;
iifgroup 2 goto antispoof
ip saddr @downstream counter packets 0 bytes 0 drop
I looked initially in /etc/iproute2/groups in sys-firewall, but there’s only the default group (0) there.
Note that the @downstream set is clearly defined on sys-firewall.
fi
nft "$nftables_cmd element $ipt qubes allowed { \"$vif\" . $addr }
$nftables_cmd element $ipt qubes downstream { $addr }"
done
# if no IPv6 is assigned, IPv6 traffic on the interface is
# implicitly considered spoofed as there is no entry in the
# "allowed" map
fi
if [ "$command" = "online" ]; then
ip link set dev "${vif}" group 2 up
fi
if [ "${ip}" ]; then
# If we've been given a list of IP addresses, then add routes from dom0 to
# the guest using those addresses.
for addr in ${ip};
do
if [[ "$addr" = *:* ]] && [[ "$ipv6_disabled" != '0' ]]; then
log error "Cannot set IPv6 route to ${addr}, IPv6 disabled in the kernel"
continue
I think it was arbitrary choice by @1choice here:
tasket:master ← 1cho1ce:replace-iptables-with-nftables
opened 07:01PM - 25 May 23 UTC
Qubes dropped iptables support and replaced it with nftables:
https://github.co… m/QubesOS/qubes-core-agent-linux/commit/28b95535c7cbd15543c804e822c0e4c997f5966e
This pull request replaces iptables with nftables.
Removed `allow established input` rules from `proxy-firewall-restrict` since they are already present in nft tables ip/ip6 qubes.
TODO: Need to think of a better way to check in `--check-firewall` in `qubes-vpn-setup` script if the forward drop rules are present (or `proxy-firewall-restrict` script finished successfully).
And you can use any other unused group number instead of 9.
