I’m on Qubes 4.2.3 / Fedora 41 and I have on /etc/environment
QT_STYLE_OVERRIDE=adwaita-dark
Has anyone experienced this before? If I select the Open Qube Manager from the upper right Qubes Domains icon. The Qube Manger launches but I notice small fonts.
See below
If I launched the Qubes Manager via the top left side icon (Open Qubes Application Menu / Qubes Tools / Qube Manager it opens but the font is bigger.
See below
Anyway is there a way to make the former bigger the same as the latter
Thanks for the help.
You could check "Application Menu > Settings > Appearance > Fonts > DPI.
The default of 96 looks good …
I’m still on Fedora-40, so you are ahead of me, but the DPI setting expands and contracts the whole of my Qubes Manager, including the size of the characters
Thanks for replying back. I also use this and adjusted mine to 105 dpi.
My issue is that when I open the Qube Manager on the upper top RIGHT side of the screen (the qube icon) near the login name the whole Qube Manager interface has small fonts.
But if I access the Qube Manager on the upper top LEFT side of the screen (Open Qubes Application Menu / widget icon / Qubes Tool / Qube Manager the whole interface follows the DPI settings.
Anyway it’s just a small thing and I was just wondering if it’s just me having these issues.
Yes, same with my version 4.2.3 Qubes Manager.
At least after playing with System Settings > Appearance > Fonts, the font sizes are different.
I don’t know whether it is a bug, or perhaps we should be pleased that we have a choice
----------Qube Tools > Qube Manager---------Qube Domains Widget > Open Qubes Manager
I.e. invoked by “Qubes Tools”, the Qubes Manager is easier to see, but takes up more screen width.
Thanks for replying back… at least I’m not alone on this
