Qubes-dist-upgrade script error 4.3.rc-2
sudo qubes-dom0-update  --action=distro-sync --force-xen-upgrade --allowerasing
results with the same error.
Same error for me.
Quite the fresh qubes.
Did nothing on it. Just eval the laptop.
I installed a few packages in dom0 but nothing with a lot of dependencies. Like thunderbolt tools and htop.
Kernel is latest
Standard setup regarding usb vm. Netvm disposable. Whonix installed and dispvm feature on.
Dom0 had testing repo enabled becaue without it the dist upgrader wasnt available.
It was updated with testing on. Before distupgrade.
Template repos are entirely default.
Default templates are fedora 42 xfce for disposable net and debian 13 xfce for appvms.
All templates updated before.
During dist upgrade there was a new dnf config via rpmnew. And i had to issue keep running for sys firewall because it would have shut that down despite sys-whonix updatevm depending on it.
Anything new here?
Backlink:
How do I get DNF to tell me more about whx dnf would be removed?
I can’t find the flags for it anymore.
Can anybody having the The operation would result in removing the following protected packages: dnf issue share full list of packages installed in dom0? You can get it using rpm -qa command.
Here you go. Let me know if you need anything else.
libibverbs-41.0-1.fc37.x86_64
libpcap-1.10.4-1.fc37.x86_64
libnl3-cli-3.7.0-2.fc37.x86_64
libteam-1.31-6.fc37.x86_64
device-mapper-persistent-data-0.9.0-8.fc37.x86_64
xcb-util-image-0.4.0-20.fc37.x86_64
libxkbcommon-x11-1.4.1-2.fc37.x86_64
xcb-util-keysyms-0.4.0-18.fc37.x86_64
xcb-util-renderutil-0.3.9-21.fc37.x86_64
xcb-util-wm-0.4.1-23.fc37.x86_64
grub2-pc-modules-2.06-4.fc37.noarch
nano-6.4-1.fc37.x86_64
nano-default-editor-6.4-1.fc37.noarch
libb2-0.98.1-7.fc37.x86_64
libimagequant-2.17.0-3.fc37.x86_64
woff2-1.0.2-15.fc37.x86_64
nss-softokn-freebl-3.94.0-2.fc37.x86_64
nss-softokn-3.94.0-2.fc37.x86_64
alsa-ucm-1.2.9-1.fc37.noarch
sequoia-sqv-1.1.0-5.fc37.x86_64
libksba-1.6.3-1.fc37.x86_64
mozjs102-102.15.1-1.fc37.x86_64
libss-1.46.5-3.fc37.x86_64
e2fsprogs-1.46.5-3.fc37.x86_64
iceauth-1.0.9-2.fc37.x86_64
jasper-libs-3.0.6-1.fc37.x86_64
libv4l-1.22.1-4.fc37.x86_64
libcomps-0.1.20-1.fc37.x86_64
bzip2-1.0.8-12.fc37.x86_64
unzip-6.0-58.fc37.x86_64
double-conversion-3.1.5-7.fc37.x86_64
gc-8.0.6-4.fc37.x86_64
graphite2-1.3.14-10.fc37.x86_64
highway-1.0.7-1.fc37.x86_64
inih-57-1.fc37.x86_64
xfsprogs-6.1.0-2.fc37.x86_64
libvmaf-2.3.0-4.fc37.x86_64
mpdecimal-2.5.1-4.fc37.x86_64
openal-soft-1.22.2-6.fc37.x86_64
protobuf-3.19.6-1.fc37.x86_64
soundtouch-2.3.1-3.fc37.x86_64
taglib-1.12-7.fc37.x86_64
tcl-8.6.12-3.fc37.x86_64
less-633-1.fc37.x86_64
xdg-user-dirs-0.18-1.fc37.x86_64
compat-readline5-5.2-42.fc37.x86_64
memstrack-0.2.4-3.fc37.x86_64
ncurses-6.4-3.20230114.fc37.x86_64
perl-base-2.27-494.fc37.noarch
perl-Text-Tabs+Wrap-2023.0511-1.fc37.noarch
perl-if-0.61.000-494.fc37.noarch
perl-IO-Socket-IP-0.41-490.fc37.noarch
perl-locale-1.10-494.fc37.noarch
perl-Time-Local-1.300-489.fc37.noarch
perl-File-Path-2.18-489.fc37.noarch
perl-Pod-Escapes-1.07-489.fc37.noarch
perl-Class-Struct-0.66-494.fc37.noarch
perl-Term-ANSIColor-5.01-490.fc37.noarch
perl-IPC-Open3-1.22-494.fc37.noarch
perl-POSIX-2.03-494.fc37.x86_64
perl-HTTP-Tiny-0.086-1.fc37.noarch
perl-subs-1.04-494.fc37.noarch
perl-File-Temp-0.231.100-489.fc37.noarch
perl-Term-Cap-1.17-489.fc37.noarch
perl-Pod-Simple-3.43-490.fc37.noarch
perl-Socket-2.036-1.fc37.x86_64
perl-SelectSaver-1.02-494.fc37.noarch
perl-Symbol-1.09-494.fc37.noarch
perl-File-stat-1.12-494.fc37.noarch
perl-Pod-Perldoc-3.28.01-490.fc37.noarch
perl-podlators-4.14-489.fc37.noarch
perl-Fcntl-1.15-494.fc37.x86_64
perl-Text-ParseWords-3.31-489.fc37.noarch
perl-IO-1.50-494.fc37.x86_64
perl-overloading-0.02-494.fc37.noarch
perl-Pod-Usage-2.03-3.fc37.noarch
perl-mro-1.26-494.fc37.x86_64
perl-Errno-1.36-494.fc37.x86_64
perl-File-Basename-2.85-494.fc37.noarch
perl-Getopt-Std-1.13-494.fc37.noarch
perl-MIME-Base64-3.16-489.fc37.x86_64
perl-Scalar-List-Utils-1.63-489.fc37.x86_64
perl-Storable-3.26-489.fc37.x86_64
perl-constant-1.33-490.fc37.noarch
perl-parent-0.238-489.fc37.noarch
perl-vars-1.05-494.fc37.noarch
perl-Getopt-Long-2.54-1.fc37.noarch
perl-overload-1.35-494.fc37.noarch
perl-Carp-1.52-489.fc37.noarch
perl-Exporter-5.77-489.fc37.noarch
perl-NDBM_File-1.15-494.fc37.x86_64
perl-PathTools-3.84-489.fc37.x86_64
perl-DynaLoader-1.52-494.fc37.x86_64
perl-Encode-3.19-492.fc37.x86_64
perl-libs-5.36.1-494.fc37.x86_64
perl-interpreter-5.36.1-494.fc37.x86_64
perl-lib-0.65-494.fc37.x86_64
cdparanoia-libs-10.2-40.fc37.x86_64
diffutils-3.8-3.fc37.x86_64
dosfstools-4.2-4.fc37.x86_64
duktape-2.6.0-3.fc37.x86_64
libproxy-duktape-0.4.18-3.fc37.x86_64
gettext-envsubst-0.21.1-1.fc37.x86_64
gettext-runtime-0.21.1-1.fc37.x86_64
gettext-0.21.1-1.fc37.x86_64
gpm-libs-1.20.7-41.fc37.x86_64
hyphen-2.8.8-18.fc37.x86_64
libargon2-20190702-1.fc37.x86_64
libasyncns-0.8-23.fc37.x86_64
pulseaudio-libs-16.1-4.fc37.x86_64
libatomic-12.3.1-1.fc37.x86_64
libdaemon-0.14-24.fc37.x86_64
teamd-1.31-6.fc37.x86_64
libdatrie-0.2.13-4.fc37.x86_64
libthai-0.1.29-3.fc37.x86_64
libdav1d-1.2.1-1.fc37.x86_64
libestr-0.1.11-4.fc37.x86_64
libexif-0.6.24-3.fc37.x86_64
libfastjson-0.99.9-4.fc37.x86_64
libldac-2.0.2.3-11.fc37.x86_64
libmd-1.1.0-1.fc37.x86_64
libbsd-0.11.7-2.fc37.x86_64
libndp-1.8-4.fc37.x86_64
libnfnetlink-1.0.1-22.fc37.x86_64
libnetfilter_conntrack-1.0.8-5.fc37.x86_64
iptables-libs-1.8.8-5.fc37.x86_64
libpipeline-1.5.6-2.fc37.x86_64
libpkgconf-1.8.0-3.fc37.x86_64
pkgconf-pkg-config-1.8.0-3.fc37.x86_64
fwupd-efi-1.4-1.fc37.x86_64
libzstd-devel-1.5.5-1.fc37.x86_64
zlib-devel-1.2.12-5.fc37.x86_64
elfutils-libelf-devel-0.190-2.fc37.x86_64
libqb-2.0.6-3.fc37.x86_64
libsamplerate-0.2.2-3.fc37.x86_64
libsbc-1.5-4.fc37.x86_64
libsigsegv-2.14-3.fc37.x86_64
libsmbios-2.4.3-7.fc37.x86_64
libsysfs-2.1.1-4.fc37.x86_64
libtommath-1.2.0-11.fc37.x86_64
libtomcrypt-1.18.2-15.fc37.x86_64
libtraceevent-1.7.2-1.fc37.x86_64
libudfread-1.1.2-4.fc37.x86_64
liburing-2.3-1.fc37.x86_64
libverto-0.3.2-4.fc37.x86_64
libvisual-0.4.0-36.fc37.x86_64
libvpx-1.12.0-4.fc37.x86_64
libwmf-lite-0.2.12-9.fc37.x86_64
linux-atm-libs-2.5.1-33.fc37.x86_64
iproute-tc-5.18.0-2.fc37.x86_64
npth-1.6-9.fc37.x86_64
oniguruma-6.9.8-2.D20220919gitb041f6d.fc37.x86_64
jq-1.6-14.fc37.x86_64
openpgm-5.2.122-29.fc37.x86_64
pciutils-libs-3.9.0-2.fc37.x86_64
pcre2-utf16-10.40-1.fc37.1.x86_64
pcsc-lite-libs-1.9.9-1.fc37.x86_64
qrencode-libs-4.1.1-3.fc37.x86_64
rav1e-libs-0.6.6-3.fc37.x86_64
rmt-1.6-7.fc37.x86_64
sgpio-1.2.0.10-35.fc37.x86_64
svt-av1-libs-1.1.0-2.fc37.x86_64
systemd-boot-unsigned-251.19-1.fc37.x86_64
twolame-libs-0.4.0-1.fc37.x86_64
vte-profile-0.70.6-1.fc37.x86_64
wavpack-5.5.0-2.fc37.x86_64
xxd-9.0.2120-1.fc37.x86_64
vim-common-9.0.2120-1.fc37.x86_64
libwacom-data-2.6.0-1.fc37.noarch
libssh-config-0.10.5-1.fc37.noarch
libX11-common-1.8.4-1.fc37.noarch
libX11-1.8.4-1.fc37.x86_64
libXext-1.3.4-9.fc37.x86_64
libXfixes-6.0.0-4.fc37.x86_64
libXrender-0.9.10-17.fc37.x86_64
libXrandr-1.5.2-9.fc37.x86_64
libXi-1.8-3.fc37.x86_64
libXinerama-1.1.4-11.fc37.x86_64
libXdamage-1.1.5-8.fc37.x86_64
libXt-1.2.1-3.fc37.x86_64
libXmu-1.1.3-9.fc37.x86_64
libXcursor-1.2.1-2.fc37.x86_64
libXcomposite-0.4.5-8.fc37.x86_64
libXtst-1.2.3-17.fc37.x86_64
libxkbfile-1.1.0-9.fc37.x86_64
startup-notification-0.12-24.fc37.x86_64
xkbcomp-1.4.5-4.fc37.x86_64
xhost-1.0.8-4.fc37.x86_64
xrdb-1.2.1-4.fc37.x86_64
libXres-1.2.1-3.fc37.x86_64
libXv-1.0.11-17.fc37.x86_64
libXxf86vm-1.1.4-19.fc37.x86_64
libXpm-3.5.15-2.fc37.x86_64
libXaw-1.0.14-3.fc37.x86_64
libglvnd-glx-1.5.0-1.fc37.x86_64
mesa-libGL-23.0.3-1.fc37.x86_64
glx-utils-8.4.0-14.20210504git0f9e7d9.fc37.x86_64
libva-2.16.0-1.fc37.x86_64
libXvMC-1.0.12-8.fc37.x86_64
setxkbmap-1.3.3-3.fc37.x86_64
libxdo-3.20211022.1-1.fc37.x86_64
xdotool-3.20211022.1-1.fc37.x86_64
xorg-x11-xauth-1.1.2-2.fc37.x86_64
xset-1.2.4-5.fc37.x86_64
xrandr-1.5.1-5.fc37.x86_64
libXScrnSaver-1.2.3-11.fc37.x86_64
dbus-x11-1.14.10-1.fc37.x86_64
libXpresent-1.0.0-17.fc37.x86_64
xmodmap-1.0.11-2.fc37.x86_64
xprop-1.2.5-2.fc37.x86_64
langtable-0.0.64-1.fc37.noarch
kbd-misc-2.5.1-3.fc37.noarch
kbd-legacy-2.5.1-3.fc37.noarch
kbd-2.5.1-3.fc37.x86_64
ipxe-roms-qemu-20220210-2.git64113751.fc37.noarch
google-noto-cjk-fonts-common-20201206-5.fc37.noarch
gawk-all-langpacks-5.1.1-4.fc37.x86_64
gawk-5.1.1-4.fc37.x86_64
emacs-filesystem-28.3-0.rc1.fc37.noarch
coreutils-common-9.1-8.fc37.x86_64
python-pip-wheel-22.2.2-3.fc37.noarch
grub2-tools-minimal-2.06-4.fc37.x86_64
python3-libs-3.11.6-1.fc37.x86_64
python3-3.11.6-1.fc37.x86_64
libevent-2.1.12-7.fc37.x86_64
grubby-8.40-66.fc37.x86_64
krb5-libs-1.19.2-13.fc37.x86_64
libtirpc-1.3.3-1.rc1.fc37.x86_64
libnsl2-2.0.0-4.fc37.x86_64
libssh-0.10.5-1.fc37.x86_64
openldap-2.6.6-1.fc37.x86_64
libkcapi-1.4.0-2.fc37.x86_64
libkcapi-hmaccalc-1.4.0-2.fc37.x86_64
crypto-policies-scripts-20220815-1.gite4ed860.fc37.noarch
crypto-policies-20220815-1.gite4ed860.fc37.noarch
cracklib-dicts-2.9.7-30.fc37.x86_64
cracklib-2.9.7-30.fc37.x86_64
libpwquality-1.4.5-3.fc37.x86_64
gzip-1.12-2.fc37.x86_64
libcurl-7.85.0-12.fc37.x86_64
authselect-1.4.2-1.fc37.x86_64
kpartx-0.9.0-4.fc37.x86_64
device-mapper-1.02.171-6.fc37.x86_64
device-mapper-libs-1.02.171-6.fc37.x86_64
elfutils-debuginfod-client-0.190-2.fc37.x86_64
elfutils-default-yama-scope-0.190-2.fc37.noarch
elfutils-libs-0.190-2.fc37.x86_64
tpm2-tools-5.4-1.fc37.x86_64
coreutils-9.1-8.fc37.x86_64
ca-certificates-2023.2.60_v7.0.306-1.0.fc37.noarch
openssl-libs-3.0.9-1.fc37.x86_64
kmod-libs-30-2.fc37.x86_64
libarchive-3.6.1-3.fc37.x86_64
kmod-30-2.fc37.x86_64
pam-1.5.2-14.fc37.x86_64
cryptsetup-libs-2.6.1-1.fc37.x86_64
tpm2-tss-3.2.2-1.fc37.x86_64
libfido2-1.11.0-3.fc37.x86_64
rpm-libs-4.18.2-1.fc37.x86_64
rpm-4.18.2-1.fc37.x86_64
authselect-libs-1.4.2-1.fc37.x86_64
util-linux-2.38.1-1.fc37.x86_64
systemd-networkd-251.19-1.fc37.x86_64
systemd-pam-251.19-1.fc37.x86_64
systemd-resolved-251.19-1.fc37.x86_64
systemd-251.19-1.fc37.x86_64
systemd-udev-251.19-1.fc37.x86_64
dracut-059-5.fc37.x86_64
grub2-tools-2.06-4.fc37.x86_64
gnutls-3.8.1-1.fc37.x86_64
glib2-2.74.7-2.fc37.x86_64
atk-2.38.0-2.fc37.x86_64
freetype-2.12.1-3.fc37.x86_64
harfbuzz-5.2.0-1.fc37.x86_64
libxfce4util-4.16.0-6.fc37.x86_64
fontconfig-2.14.1-2.fc37.x86_64
cairo-1.17.6-2.fc37.x86_64
cairo-gobject-1.17.6-2.fc37.x86_64
xfconf-4.16.0-8.fc37.x86_64
qt5-qtbase-common-5.15.10-9.fc37.noarch
qt5-qtbase-5.15.10-9.fc37.x86_64
polkit-libs-121-4.fc37.2.x86_64
polkit-121-4.fc37.2.x86_64
polkit-pkla-compat-0.1-22.fc37.x86_64
libgudev-237-3.fc37.x86_64
json-glib-1.6.6-3.fc37.x86_64
glibmm2.4-2.66.6-1.fc37.x86_64
shared-mime-info-2.2-2.fc37.x86_64
gdk-pixbuf2-2.42.10-1.fc37.x86_64
libnotify-0.8.2-1.fc37.x86_64
python3-setuptools-62.6.0-3.fc37.noarch
python3-six-1.16.0-8.fc37.noarch
gstreamer1-1.20.5-1.fc37.x86_64
libxklavier-5.4-21.fc37.x86_64
atkmm-2.28.3-1.fc37.x86_64
parted-3.5-6.fc37.x86_64
libblockdev-utils-2.28-2.fc37.x86_64
avahi-libs-0.8-18.fc37.x86_64
cairomm-1.14.5-1.fc37.x86_64
libmodulemd-2.15.0-2.fc37.x86_64
pulseaudio-libs-glib2-16.1-4.fc37.x86_64
python3-dbus-1.3.2-1.fc37.x86_64
satyr-0.42-1.fc37.x86_64
libreport-2.17.11-1.fc37.x86_64
which-2.21-39.fc37.x86_64
device-mapper-event-libs-1.02.171-6.fc37.x86_64
python3-inotify-0.9.6-28.fc37.noarch
python3-lxml-4.9.1-1.fc37.x86_64
dmraid-libs-1.0.0.rc16-53.fc37.x86_64
cups-libs-2.4.7-2.fc37.x86_64
libXft-2.3.4-3.fc37.x86_64
pango-1.50.14-1.fc37.x86_64
librsvg2-2.54.6-1.fc37.x86_64
pangomm-2.46.3-1.fc37.x86_64
gobject-introspection-1.74.0-1.fc37.x86_64
python3-gobject-base-noarch-3.42.2-2.fc37.noarch
python3-gobject-base-3.42.2-2.fc37.x86_64
PackageKit-glib-1.2.6-2.fc37.x86_64
libdbusmenu-16.04.0-20.fc37.x86_64
cronie-anacron-1.6.1-3.fc37.x86_64
cronie-1.6.1-3.fc37.x86_64
crontabs-1.11-28.20190603git.fc37.noarch
logrotate-3.20.1-3.fc37.x86_64
plymouth-22.02.122-4.fc37.x86_64
plymouth-scripts-22.02.122-4.fc37.x86_64
xmlrpc-c-1.51.08-1.fc37.x86_64
zchunk-libs-1.3.2-1.fc37.x86_64
python3-pyyaml-6.0-5.fc37.x86_64
python3-systemd-235-1.fc37.x86_64
libsolv-0.7.25-1.fc37.x86_64
xmlrpc-c-client-1.51.08-1.fc37.x86_64
libreport-web-2.17.11-1.fc37.x86_64
libreport-plugin-reportuploader-2.17.11-1.fc37.x86_64
upower-0.99.20-2.fc37.x86_64
device-mapper-event-1.02.171-6.fc37.x86_64
libblockdev-2.28-2.fc37.x86_64
python3-blockdev-2.28-2.fc37.x86_64
libblockdev-loop-2.28-2.fc37.x86_64
libblockdev-swap-2.28-2.fc37.x86_64
python3-pyparted-3.12.0-6.fc37.x86_64
gdk-pixbuf2-modules-2.42.10-1.fc37.x86_64
gtk-update-icon-cache-3.24.38-1.fc37.x86_64
libgusb-0.4.5-1.fc37.x86_64
colord-libs-1.4.6-2.fc37.x86_64
python3-cairo-1.21.0-3.fc37.x86_64
python3-gobject-3.42.2-2.fc37.x86_64
libXfont2-2.0.3-13.fc37.x86_64
NetworkManager-libnm-1.40.18-1.fc37.x86_64
NetworkManager-1.40.18-1.fc37.x86_64
dconf-0.40.0-7.fc37.x86_64
desktop-file-utils-0.26-7.fc37.x86_64
xdg-utils-1.1.3-15.fc37.noarch
gsettings-desktop-schemas-43.0-1.fc37.x86_64
glib-networking-2.74.0-1.fc37.x86_64
libsoup-2.74.3-1.fc37.x86_64
libsoup3-3.2.2-3.fc37.x86_64
gssdp-1.4.1-1.fc37.x86_64
javascriptcoregtk4.1-2.42.2-1.fc37.x86_64
libgcab1-1.5-1.fc37.x86_64
libsecret-0.20.5-2.fc37.x86_64
libudisks2-2.9.4-5.fc37.x86_64
libuser-0.63-13.fc37.x86_64
ima-evm-utils-1.4-6.fc37.x86_64
cryptsetup-2.6.1-1.fc37.x86_64
pciutils-3.9.0-2.fc37.x86_64
libfsverity-1.4-8.fc37.x86_64
scrypt-1.3.2-1.fc37.x86_64
socat-1.7.4.2-3.fc37.x86_64
binutils-gold-2.38-27.fc37.x86_64
binutils-2.38-27.fc37.x86_64
xorg-x11-xinit-1.4.0-15.fc37.x86_64
python3-distro-1.7.0-3.fc37.noarch
python3-docutils-0.18.1-2.fc37.noarch
python3-idna-3.3-4.fc37.noarch
python3-libselinux-3.5-1.fc37.x86_64
python3-looseversion-1.2.0-1.fc37.noarch
python3-markupsafe-2.1.1-3.fc37.x86_64
python3-jinja2-3.0.3-5.fc37.noarch
python3-pid-2.2.3-15.fc37.noarch
python3-pyxdg-0.27-6.fc37.noarch
python3-tqdm-4.66.1-1.fc37.noarch
pmount-0.9.23-24.fc37.x86_64
passwd-0.80-13.fc37.x86_64
usermode-1.114-5.fc37.x86_64
hddtemp-0.3-0.51.beta15.fc37.x86_64
gcab-1.5-1.fc37.x86_64
gupnp-1.4.4-1.fc37.x86_64
gupnp-igd-1.2.0-6.fc37.x86_64
libnice-0.1.19-2.fc37.x86_64
libtracker-sparql-3.4.2-1.fc37.x86_64
NetworkManager-team-1.40.18-1.fc37.x86_64
tigervnc-server-minimal-1.13.1-6.fc37.x86_64
dmraid-events-1.0.0.rc16-53.fc37.x86_64
dmraid-1.0.0.rc16-53.fc37.x86_64
libblockdev-dm-2.28-2.fc37.x86_64
lvm2-libs-2.03.09-6.fc37.x86_64
lvm2-2.03.09-6.fc37.x86_64
libblockdev-lvm-2.28-2.fc37.x86_64
plymouth-plugin-label-22.02.122-4.fc37.x86_64
plymouth-plugin-script-22.02.122-4.fc37.x86_64
rsyslog-logrotate-8.2204.0-3.fc37.x86_64
rsyslog-8.2204.0-3.fc37.x86_64
python3-dasbus-1.6-6.fc37.noarch
python3-pydbus-0.6.0-20.fc37.noarch
grub2-pc-2.06-4.fc37.x86_64
libreport-cli-2.17.11-1.fc37.x86_64
avahi-glib-0.8-18.fc37.x86_64
libblockdev-btrfs-2.28-2.fc37.x86_64
libblockdev-fs-2.28-2.fc37.x86_64
libblockdev-part-2.28-2.fc37.x86_64
python3-dateutil-2.8.2-4.fc37.noarch
python3-productmd-1.37-1.fc37.noarch
python3-pyudev-0.23.2-3.fc37.noarch
python3-pip-22.2.2-3.fc37.noarch
jxl-pixbuf-loader-0.7.0-5.fc37.x86_64
libjxl-0.7.0-5.fc37.x86_64
libaom-3.7.0-1.fc37.x86_64
libavif-0.11.1-4.fc37.x86_64
libappstream-glib-0.8.1-1.fc37.x86_64
libxmlb-0.3.11-1.fc37.x86_64
iio-sensor-proxy-3.4-2.fc37.x86_64
libmanette-0.2.6-5.fc37.x86_64
libwacom-2.6.0-1.fc37.x86_64
libinput-1.22.1-1.fc37.x86_64
qt5-qtbase-gui-5.15.10-9.fc37.x86_64
qt5-qtdeclarative-5.15.10-1.fc37.x86_64
xorg-x11-drv-libinput-1.2.1-2.fc37.x86_64
xorg-x11-drv-ati-19.1.0-8.fc37.x86_64
xorg-x11-drv-dummy-0.3.7-17.fc37.x86_64
xorg-x11-drv-evdev-2.10.6-12.fc37.x86_64
xorg-x11-drv-fbdev-0.5.0-11.fc37.x86_64
xorg-x11-drv-intel-2.99.917-54.20210115.fc37.x86_64
xorg-x11-drv-nouveau-1.0.17-4.fc37.x86_64
xorg-x11-drv-openchrome-0.6.400-4.20210215git5dbad06.fc37.x86_64
xorg-x11-drv-qxl-0.1.5-20.fc35.x86_64
xorg-x11-drv-vesa-2.5.0-4.fc37.x86_64
xorg-x11-drv-vmware-13.2.1-16.fc35.x86_64
xorg-x11-drv-wacom-1.1.0-2.fc37.x86_64
qt5-qtconnectivity-5.15.10-1.fc37.x86_64
qt5-qtlocation-5.15.10-1.fc37.x86_64
qt5-qtsensors-5.15.10-1.fc37.x86_64
qt5-qtwebchannel-5.15.10-1.fc37.x86_64
qt5-qtxmlpatterns-5.15.10-1.fc37.x86_64
qt5-qtsvg-5.15.10-1.fc37.x86_64
qt5-qttools-libs-designer-5.15.10-2.fc37.x86_64
qt5-qttools-libs-help-5.15.10-2.fc37.x86_64
qt5-qtx11extras-5.15.10-1.fc37.x86_64
accountsservice-22.08.8-2.fc37.x86_64
pcsc-lite-ccid-1.5.0-2.fc37.x86_64
pcsc-lite-1.9.9-1.fc37.x86_64
gnupg2-2.3.8-1.fc37.x86_64
gpgme-1.17.0-4.fc37.x86_64
libjcat-0.1.13-1.fc37.x86_64
ostree-libs-2022.7-2.fc37.x86_64
ostree-2022.7-2.fc37.x86_64
librepo-1.17.0-1.fc37.x86_64
libdnf-0.72.0-1.fc37.x86_64
python3-libdnf-0.72.0-1.fc37.x86_64
python3-hawkey-0.72.0-1.fc37.x86_64
PackageKit-1.2.6-2.fc37.x86_64
rpm-sign-libs-4.18.2-1.fc37.x86_64
rtkit-0.11-33.fc37.x86_64
pipewire-0.3.84-1.fc37.x86_64
pipewire-libs-0.3.84-1.fc37.x86_64
wireplumber-0.4.14-1.fc37.x86_64
wireplumber-libs-0.4.14-1.fc37.x86_64
pipewire-pulseaudio-0.3.84-1.fc37.x86_64
pipewire-jack-audio-connection-kit-libs-0.3.84-1.fc37.x86_64
qt5-qtserialport-5.15.10-1.fc37.x86_64
qt5-qtwebsockets-5.15.10-1.fc37.x86_64
libbluray-1.3.4-1.fc37.x86_64
harfbuzz-icu-5.2.0-1.fc37.x86_64
libraqm-0.8.0-2.fc37.x86_64
mkfontscale-1.2.2-2.fc37.x86_64
urw-base35-fonts-legacy-20200910-15.fc37.noarch
GraphicsMagick-1.3.38-3.fc37.x86_64
at-spi2-core-2.44.1-2.fc37.x86_64
at-spi2-atk-2.38.0-5.fc37.x86_64
bluez-5.68-1.fc37.x86_64
enchant2-2.3.4-1.fc37.x86_64
gcr3-base-3.41.1-3.fc37.x86_64
graphene-1.10.6-4.fc37.x86_64
gstreamer1-plugins-base-1.20.5-1.fc37.x86_64
gvfs-client-1.50.4-1.fc37.x86_64
libbabeltrace-1.5.8-12.fc37.x86_64
libcloudproviders-0.3.1-6.fc37.x86_64
libgtop2-2.40.0-9.fc37.x86_64
malcontent-libs-0.11.0-1.fc37.x86_64
flatpak-libs-1.14.4-1.fc37.x86_64
qemu-img-7.0.0-15.fc37.x86_64
wmctrl-1.07-33.fc37.x86_64
wpebackend-fdo-1.14.2-1.fc37.x86_64
xdg-dbus-proxy-0.1.4-2.fc37.x86_64
xss-lock-0.3.0-18.20140302git.fc37.x86_64
chrony-4.3-1.fc37.x86_64
ntfsprogs-2022.10.3-1.fc37.x86_64
initscripts-service-10.19-1.fc37.noarch
lm_sensors-3.6.0-12.fc37.x86_64
mdadm-4.2-2.fc37.x86_64
libblockdev-mdraid-2.28-2.fc37.x86_64
numad-0.5-37.20150602git.fc37.x86_64
usb_modeswitch-2.6.1-5.fc37.x86_64
usb_modeswitch-data-20191128-7.fc37.noarch
usbguard-1.1.0-4.fc37.x86_64
cyrus-sasl-2.1.28-8.fc37.x86_64
openssh-9.3p1-11.fc37.x86_64
drpm-0.5.2-1.fc37.x86_64
createrepo_c-libs-0.21.1-1.fc37.x86_64
createrepo_c-0.21.1-1.fc37.x86_64
rpm-build-libs-4.18.2-1.fc37.x86_64
python3-rpm-4.18.2-1.fc37.x86_64
python3-simpleline-1.9.0-4.fc37.noarch
sudo-1.9.13-1.p2.fc37.x86_64
sudo-python-plugin-1.9.13-1.p2.fc37.x86_64
libretls-3.8.1-1.fc37.x86_64
netcat-1.226-1.fc37.x86_64
libshout-2.4.6-1.fc37.x86_64
gstreamer1-plugins-good-1.20.5-1.fc37.x86_64
libssh2-1.10.0-5.fc37.x86_64
unbound-anchor-1.18.0-1.fc37.x86_64
unbound-libs-1.18.0-1.fc37.x86_64
gnutls-dane-3.8.1-1.fc37.x86_64
gnutls-utils-3.8.1-1.fc37.x86_64
guile22-2.2.7-6.fc37.x86_64
make-4.3-11.fc37.x86_64
nss-sysinit-3.94.0-2.fc37.x86_64
nss-3.94.0-2.fc37.x86_64
libsrtp-2.3.0-9.fc37.x86_64
gstreamer1-plugins-bad-free-1.20.5-1.fc37.x86_64
qt5-qtmultimedia-5.15.10-1.fc37.x86_64
volume_key-libs-0.3.12-17.fc37.x86_64
libblockdev-crypto-2.28-2.fc37.x86_64
fwupd-plugin-uefi-capsule-data-1.8.17-1.fc37.x86_64
fwupd-1.8.17-1.fc37.x86_64
gvfs-1.50.4-1.fc37.x86_64
sound-theme-freedesktop-0.8-18.fc37.noarch
libcanberra-0.30-29.fc37.x86_64
libcanberra-gtk3-0.30-29.fc37.x86_64
gtk3-3.24.38-1.fc37.x86_64
libxfce4ui-4.16.1-3.fc37.x86_64
exo-4.16.4-2.fc37.x86_64
garcon-4.16.1-6.fc37.x86_64
gnome-packagekit-common-3.32.0-10.fc37.x86_64
keybinder3-0.3.2-14.fc37.x86_64
libdbusmenu-gtk3-16.04.0-20.fc37.x86_64
xfce4-panel-4.16.5-1.fc37.x86_64
libhandy-1.8.2-1.fc37.x86_64
webkit2gtk4.1-2.42.2-1.fc37.x86_64
yelp-libs-42.2-1.fc37.x86_64
yelp-42.2-1.fc37.x86_64
Thunar-4.16.11-2.fc37.x86_64
xfce4-notifyd-0.6.4-1.fc37.x86_64
libappindicator-gtk3-12.10.1-0.fc37.x86_64
gnome-packagekit-installer-3.32.0-10.fc37.x86_64
gnome-packagekit-updater-3.32.0-10.fc37.x86_64
xfce4-settings-4.16.5-1.fc37.x86_64
xfce4-screenshooter-1.10.3-1.fc37.x86_64
xfce-polkit-0.3-9.fc37.x86_64
anaconda-widgets-37.12.6-6.fc37.x86_64
gtk-unico-engine-1.0.3-0.20.20140109bzr152.fc37.x86_64
gtkmm3.0-3.24.7-2.fc37.x86_64
pavucontrol-5.0-7.fc37.x86_64
gtksourceview4-4.8.4-1.fc37.x86_64
libgnomekbd-3.28.1-1.fc37.x86_64
libreport-gtk-2.17.11-1.fc37.x86_64
libtimezonemap-0.4.5.2-1.fc37.x86_64
vte291-0.70.6-1.fc37.x86_64
adwaita-gtk2-theme-3.28-15.fc37.x86_64
gtk2-2.24.33-10.fc37.x86_64
libcanberra-gtk2-0.30-29.fc37.x86_64
gtk-murrine-engine-0.98.2-24.fc37.x86_64
greybird-light-theme-3.23.1-3.fc37.noarch
gtk2-engines-2.20.2-25.fc37.x86_64
gtkmm2.4-2.24.5-15.fc37.x86_64
gnome-themes-extra-3.28-15.fc37.x86_64
lightdm-gobject-1.32.0-2.fc37.x86_64
lightdm-1.32.0-2.fc37.x86_64
lightdm-gtk-2.0.8-3.fc36.x86_64
greybird-dark-theme-3.23.1-3.fc37.noarch
libglade2-2.6.4-28.fc37.x86_64
libglademm24-2.6.7-34.fc37.x86_64
device-mapper-multipath-libs-0.9.0-4.fc37.x86_64
device-mapper-multipath-0.9.0-4.fc37.x86_64
libblockdev-mpath-2.28-2.fc37.x86_64
python3-pwquality-1.4.5-3.fc37.x86_64
lsof-4.94.0-4.fc37.x86_64
cyrus-sasl-gssapi-2.1.28-8.fc37.x86_64
libvirt-libs-8.9.0-7.fc37.x86_64
libvirt-daemon-8.9.0-7.fc37.x86_64
libvirt-daemon-driver-interface-8.9.0-7.fc37.x86_64
libvirt-daemon-driver-libxl-8.9.0-7.fc37.x86_64
libvirt-daemon-driver-nodedev-8.9.0-7.fc37.x86_64
libvirt-daemon-xen-8.9.0-7.fc37.x86_64
python3-libvirt-8.9.0-7.fc37.x86_64
zeromq-4.3.4-4.fc37.x86_64
python3-zmq-23.2.0-1.fc37.x86_64
blivet-data-3.5.0-1.fc37.noarch
python3-bytesize-2.10-1.fc37.x86_64
python3-blivet-3.5.0-1.fc37.noarch
blivet-gui-runtime-2.4.2-1.fc37.noarch
python3-charset-normalizer-2.1.0-2.fc37.noarch
python3-click-8.1.3-1.fc37.noarch
python3-jmespath-1.0.0-5.fc37.noarch
python3-langtable-0.0.64-1.fc37.noarch
python3-libcomps-0.1.20-1.fc37.x86_64
python3-dnf-4.18.0-2.fc37.noarch
python3-dnf-plugins-core-4.4.3-1.fc37.noarch
dnf-utils-4.4.3-1.fc37.noarch
python3-msgpack-1.0.4-3.fc37.x86_64
python3-numpy-1.24.3-1.fc37.x86_64
python3-olefile-0.46-18.fc37.noarch
python3-pillow-9.2.0-2.fc37.x86_64
python3-ply-3.11-17.fc37.noarch
python3-pycparser-2.20-8.fc37.noarch
python3-cffi-1.15.1-2.fc37.x86_64
python3-xcffib-0.11.1-5.fc37.noarch
python3-psutil-5.9.1-1.fc37.x86_64
python3-pycryptodomex-3.19.0-1.fc37.x86_64
python3-pyparsing-3.0.9-2.fc37.noarch
python3-packaging-21.3-6.fc37.noarch
python3-pyqt5-sip-12.11.0-2.fc37.x86_64
python3-qt5-base-5.15.9-3.fc37.x86_64
python3-qt5-5.15.9-3.fc37.x86_64
python3-pysocks-1.7.1-15.fc37.noarch
python3-urllib3+socks-1.26.18-1.fc37.noarch
python3-urllib3-1.26.18-1.fc37.noarch
python3-requests-2.28.1-3.fc37.noarch
qubes-mgmt-salt-config-4.2.2-1.fc37.noarch
qubes-mgmt-salt-base-topd-4.2.1-1.fc37.noarch
python3-libreport-2.17.11-1.fc37.x86_64
python3-meh-0.50-7.fc37.noarch
python3-meh-gui-0.50-7.fc37.noarch
libreport-plugin-bugzilla-2.17.11-1.fc37.x86_64
libreport-anaconda-2.17.11-1.fc37.x86_64
qubes-mgmt-salt-base-config-4.1.2-1.fc37.noarch
qubes-mgmt-salt-4.2.2-1.fc37.noarch
qubes-mgmt-salt-admin-tools-4.2.2-1.fc37.noarch
qubes-mgmt-salt-base-4.1.7-1.fc37.noarch
python3-kickstart-3.41-1.fc37.noarch
python3-requests-file-1.5.1-7.fc37.noarch
python3-requests-ftp-0.3.1-26.fc37.noarch
anaconda-tui-37.12.6-6.fc37.x86_64
anaconda-core-37.12.6-6.fc37.x86_64
initial-setup-0.3.95-5.fc37.x86_64
python3-qasync-0.23.0-2.fc37.noarch
qubes-core-admin-addon-whonix-4.1.3-1.fc37.noarch
qubes-mgmt-salt-dom0-4.2.2-1.fc37.noarch
busybox-1.36.0-1.fc37.x86_64
anaconda-user-help-26.2-3.fc37.noarch
anaconda-gui-37.12.6-6.fc37.x86_64
initial-setup-gui-0.3.95-5.fc37.x86_64
qubes-anaconda-addon-4.2.7-1.fc37.noarch
albatross-xfwm4-theme-1.7.4-13.fc37.noarch
bluebird-xfwm4-theme-1.3-9.fc37.noarch
greybird-xfwm4-theme-3.23.1-3.fc37.noarch
xfdesktop-4.16.1-1.fc37.x86_64
xfwm4-themes-4.10.0-19.fc37.noarch
libvirt-client-8.9.0-7.fc37.x86_64
paman-0.9.4-29.fc37.x86_64
arc-theme-20221218-1.fc37.noarch
albatross-gtk2-theme-1.7.4-13.fc37.noarch
bluebird-gtk2-theme-1.3-9.fc37.noarch
greybird-xfce4-notifyd-theme-3.23.1-3.fc37.noarch
gtk-xfce-engine-3.2.0-16.fc37.x86_64
xfce4-terminal-1.0.4-2.fc37.x86_64
xfce4-pulseaudio-plugin-0.4.4-1.fc37.x86_64
albatross-gtk3-theme-1.7.4-13.fc37.noarch
xfce4-session-4.16.0-6.fc37.x86_64
xfce4-screenshooter-plugin-1.10.3-1.fc37.x86_64
xfce4-xkb-plugin-0.8.3-2.fc37.x86_64
gnome-packagekit-3.32.0-10.fc37.x86_64
xfce4-battery-plugin-1.1.4-4.fc37.x86_64
xfce4-cpugraph-plugin-1.2.6-2.fc37.x86_64
xfce4-datetime-plugin-0.8.1-5.fc37.x86_64
xfce4-diskperf-plugin-2.7.0-2.fc37.x86_64
xfce4-eyes-plugin-4.6.0-2.fc37.x86_64
xfce4-fsguard-plugin-1.1.2-5.fc37.x86_64
xfce4-genmon-plugin-4.1.1-5.fc37.x86_64
xfce4-mailwatch-plugin-1.3.0-5.fc37.x86_64
xfce4-mount-plugin-1.1.5-5.fc37.x86_64
xfce4-places-plugin-1.8.3-1.fc37.x86_64
xfce4-power-manager-4.16.0-7.fc37.x86_64
xfce4-sensors-plugin-1.4.3-5.fc37.x86_64
xfce4-systemload-plugin-1.3.1-4.fc37.x86_64
xfce4-time-out-plugin-1.1.2-4.fc37.x86_64
xfce4-timer-plugin-1.7.1-7.fc37.x86_64
xfce4-verve-plugin-2.0.1-5.fc37.x86_64
xfce4-appfinder-4.16.1-5.fc37.x86_64
xfce4-about-4.16.1-3.fc37.x86_64
xfce4-taskmanager-1.5.4-2.fc37.x86_64
openssh-askpass-9.3p1-11.fc37.x86_64
xdg-user-dirs-gtk-0.11-1.fc37.x86_64
audit-3.1.2-5.fc37.x86_64
perf-6.5.4-100.fc37.x86_64
pipewire-jack-audio-connection-kit-0.3.84-1.fc37.x86_64
pipewire-alsa-0.3.84-1.fc37.x86_64
xorg-x11-drivers-2022-2.fc37.x86_64
grub2-qubes-theme-5.14.4-5.fc37.x86_64
pinfo-0.6.10-30.fc37.x86_64
xterm-384-1.fc37.x86_64
vim-enhanced-9.0.2120-1.fc37.x86_64
irqbalance-1.9.2-1.fc37.x86_64
grub2-efi-x64-2.06-4.fc37.x86_64
alsa-utils-1.2.9-1.fc37.x86_64
at-3.2.5-4.fc37.x86_64
iputils-20221126-1.fc37.x86_64
mcelog-175-5.fc37.x86_64
man-db-2.10.2-2.fc37.x86_64
quota-4.06-8.fc37.x86_64
usbutils-015-1.fc37.x86_64
google-noto-sans-cjk-ttc-fonts-20201206-5.fc37.noarch
dump-0.4-0.50.b47.fc37.x86_64
pcmciautils-018-23.fc37.x86_64
zip-3.0-33.fc37.x86_64
ntsysv-1.24-1.fc37.x86_64
smartmontools-7.4-2.fc37.x86_64
tar-1.34-6.fc37.x86_64
vim-minimal-9.0.2120-1.fc37.x86_64
efibootmgr-18-2.fc37.x86_64
tmpwatch-2.11-23.fc37.x86_64
numactl-2.0.14-6.fc37.x86_64
man-pages-5.13-4.fc37.noarch
ed-1.18-2.fc37.x86_64
hostname-3.23-7.fc37.x86_64
symlinks-1.7-7.fc37.x86_64
time-1.9-19.fc37.x86_64
tree-2.1.0-1.fc37.x86_64
thai-scalable-waree-fonts-0.7.3-3.fc37.noarch
dejavu-sans-fonts-2.37-19.fc37.noarch
liberation-mono-fonts-2.1.5-3.fc37.noarch
liberation-sans-fonts-2.1.5-3.fc37.noarch
liberation-serif-fonts-2.1.5-3.fc37.noarch
google-noto-naskh-arabic-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-arabic-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-armenian-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-canadian-aboriginal-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-cherokee-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-ethiopic-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-georgian-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-gurmukhi-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-hebrew-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-lao-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-math-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-mono-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-sinhala-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-sans-thaana-fonts-20201206^1.git0c78c8329-8.fc37.noarch
google-noto-serif-fonts-20201206^1.git0c78c8329-8.fc37.noarch
dejavu-serif-fonts-2.37-19.fc37.noarch
google-noto-emoji-color-fonts-20220916-2.fc37.noarch
jomolhari-fonts-0.003-36.fc37.noarch
khmer-os-system-fonts-5.0-36.fc37.noarch
lohit-assamese-fonts-2.91.5-14.fc37.noarch
lohit-bengali-fonts-2.91.5-14.fc37.noarch
lohit-devanagari-fonts-2.95.5-4.fc37.noarch
lohit-gujarati-fonts-2.92.4-14.fc37.noarch
lohit-kannada-fonts-2.5.4-13.fc37.noarch
lohit-marathi-fonts-2.94.2-15.fc37.noarch
lohit-odia-fonts-2.91.2-14.fc37.noarch
lohit-tamil-fonts-2.91.3-14.fc37.noarch
lohit-telugu-fonts-2.5.5-13.fc37.noarch
paktype-naskh-basic-fonts-6.0-4.fc37.noarch
rit-meera-new-fonts-1.5.2-1.fc37.noarch
sil-mingzat-fonts-1.100-2.fc37.noarch
sil-nuosu-fonts-2.200-6.fc37.noarch
sil-padauk-fonts-3.003-10.fc37.noarch
stix-fonts-2.13b171-2.fc37.noarch
vazirmatn-fonts-33.003-2.fc37.noarch
rootfiles-8.1-32.fc37.noarch
desktop-backgrounds-basic-37.0.0-4.fc37.noarch
bluebird-gtk3-theme-1.3-9.fc37.noarch
alsa-sof-firmware-2023.09.1-1.fc37.noarch
gpg-pubkey-5323552a-6112bcdc
gpg-pubkey-8e34d89f-633c3eb9
gpg-pubkey-6d5c71b3-64108638
gpg-pubkey-beb24936-659c9647
gpg-pubkey-7f3fada4-6616f727
ModemManager-glib-1.18.12-1.fc37.x86_64
geoclue2-2.6.0-3.fc37.x86_64
redshift-1.12-16.fc37.x86_64
redshift-gtk-1.12-16.fc37.x86_64
libwnck3-43.0-9.fc37.x86_64
libdvbv5-1.22.1-4.fc37.x86_64
v4l-utils-1.22.1-4.fc37.x86_64
qubes-img-converter-dom0-1.2.18-1.fc37.noarch
qubes-menus-4.2.12-1.fc37.noarch
qubes-desktop-linux-common-4.2.12-1.fc37.noarch
xfce4-settings-qubes-4.2.3-1.fc37.noarch
python3-croniter-1.3.4-3.fc37.noarch
python3-gbulb-0.6.6-1.fc37.x86_64
qubes-usb-proxy-dom0-1.3.3-1.fc37.noarch
python3-zstd-1.4.5.1-8.fc37.x86_64
python3-more-itertools-8.12.0-5.fc37.noarch
python3-jaraco-9.0.0-3.fc37.noarch
python3-multidict-6.0.4-1.fc37.x86_64
python3-frozenlist-1.4.0-1.fc37.x86_64
python3-cryptography-37.0.2-5.fc37.x86_64
python3-pyOpenSSL-21.0.0-4.fc37.noarch
python3-aiosignal-1.3.1-1.fc37.noarch
python3-yarl-1.8.0-3.fc37.x86_64
python3-jaraco-classes-3.2.1-8.fc37.noarch
xorg-x11-server-common-1.20.14-27.fc37.x86_64
python3-zipp-3.8.1-2.fc37.noarch
python3-importlib-metadata-4.12.0-2.fc37.noarch
python3-zc-lockfile-2.0-11.fc37.noarch
python3-tornado-6.2.0-2.fc37.x86_64
python3-toml-0.10.2-9.fc37.noarch
python3-jaraco-functools-3.5.1-2.fc37.noarch
python3-cheroot-8.6.0-8.fc37.noarch
python3-jaraco-text-3.2.0-10.fc37.noarch
python3-jaraco-collections-3.0.0-12.fc37.noarch
python3-setproctitle-1.2.3-2.fc37.x86_64
python3-pytz-2023.3.post1-1.fc37.noarch
python3-tempora-5.0.2-2.fc37.noarch
python3-portend-3.1.0-7.fc37.noarch
python3-cherrypy-18.8.0-2.fc37.noarch
python3-gnupg-0.5.0-1.fc37.noarch
python3-brotli-1.0.9-9.fc37.x86_64
python3-attrs-22.1.0-1.fc37.noarch
python3-async-timeout-4.0.2-5.fc37.noarch
llhttp-8.1.1-1.fc37.x86_64
c-ares-1.21.0-1.fc37.x86_64
python3-pycares-4.3.0-1.fc37.x86_64
python3-aiodns-3.0.0-5.fc37.noarch
python3-aiohttp-3.8.5-1.fc37.x86_64
python3-aiohttp+speedups-3.8.5-1.fc37.x86_64
salt-3007.1-1.fc37.noarch
salt-minion-3007.1-1.fc37.noarch
qubes-mgmt-salt-dom0-update-4.2.2-1.fc37.noarch
xorg-x11-server-Xorg-1.20.14-27.fc37.x86_64
qubes-mgmt-salt-dom0-virtual-machines-4.2.19-1.fc37.noarch
qubes-pdf-converter-dom0-2.1.23-1.fc37.noarch
qubes-libvchan-xen-4.2.7-1.fc37.x86_64
xscreensaver-gl-base-6.08-5.fc37.x86_64
xscreensaver-base-6.08-5.fc37.x86_64
qubes-core-qrexec-libs-4.2.24-1.fc37.x86_64
qubes-core-qrexec-4.2.24-1.fc37.x86_64
qubes-artwork-4.2.4-1.fc37.noarch
qubes-desktop-linux-menu-4.2.0-1.fc37.noarch
qubes-core-qrexec-dom0-4.2.24-1.fc37.x86_64
qubes-rpm-oxide-0.2.9-1.fc37.x86_64
qubes-artwork-plymouth-4.2.4-1.fc37.noarch
qubes-artwork-anaconda-4.2.4-1.fc37.noarch
xfwm4-4.16.1-5.fc37.x86_64
fwupd-qubes-dom0-1.8.17-3.fc37.noarch
qubes-db-libs-4.2.9-1.fc37.x86_64
qubes-db-4.2.9-1.fc37.x86_64
qubes-db-dom0-4.2.9-1.fc37.x86_64
python3-qubesdb-4.2.9-1.fc37.x86_64
qubes-core-dom0-linux-kernel-install-4.2.36-1.fc37.x86_64
kernel-modules-6.12.37-1.qubes.fc37.x86_64
kernel-latest-modules-6.15.6-1.qubes.fc37.x86_64
kernel-latest-devel-6.15.6-1.qubes.fc37.x86_64
kernel-devel-6.12.37-1.qubes.fc37.x86_64
kernel-qubes-vm-6.12.37-1.qubes.fc37.x86_64
kernel-latest-qubes-vm-6.15.6-1.qubes.fc37.x86_64
kernel-latest-6.15.6-1.qubes.fc37.x86_64
kernel-6.12.37-1.qubes.fc37.x86_64
qubes-core-dom0-linux-4.2.36-1.fc37.x86_64
qubes-video-companion-dom0-1.1.6-1.fc37.noarch
libtalloc-2.3.4-3.fc37.x86_64
libtevent-0.13.0-1.fc37.x86_64
libraw1394-2.1.2-16.fc37.x86_64
samba-common-4.17.12-1.fc37.noarch
intel-mediasdk-22.5.4-1.fc37.x86_64
lpcnetfreedv-0.2-12.fc37.x86_64
codec2-1.0.5-1.fc37.x86_64
zimg-3.0.5-1.fc37.x86_64
spirv-tools-libs-2022.2-3.fc37.x86_64
libshaderc-2022.2-3.fc37.x86_64
ocl-icd-2.3.1-2.fc37.x86_64
libplacebo-4.208.0-1.fc37.x86_64
vapoursynth-libs-58-3.fc37.x86_64
libavc1394-0.5.4-18.fc37.x86_64
libdc1394-2.2.6-8.fc37.x86_64
libiec61883-1.2.0-30.fc37.x86_64
zvbi-0.2.35-19.fc37.x86_64
xvidcore-1.3.7-9.fc37.x86_64
vo-amrwbenc-0.1.3-18.fc37.x86_64
vid.stab-1.1.0-20.20201110gitf9166e9.fc37.x86_64
vamp-plugin-sdk-2.9.0-6.fc37.x86_64
tesseract-tessdata-doc-4.1.0-4.fc37.noarch
srt-libs-1.5.1-1.fc37.x86_64
soxr-0.1.3-12.fc37.x86_64
snappy-1.1.9-5.fc37.x86_64
opencore-amr-0.1.6-3.fc37.x86_64
mesa-libGLU-9.0.1-7.fc37.x86_64
mbedtls-2.28.5-1.fc37.x86_64
lv2-1.18.8-2.fc37.x86_64
lmdb-libs-0.9.31-1.fc37.x86_64
libldb-2.6.2-1.fc37.x86_64
libwbclient-4.17.12-1.fc37.x86_64
samba-client-libs-4.17.12-1.fc37.x86_64
samba-common-libs-4.17.12-1.fc37.x86_64
libsmbclient-4.17.12-1.fc37.x86_64
libvdpau-1.5-2.fc37.x86_64
libavutil-free-5.1.4-1.fc37.x86_64
libswresample-free-5.1.4-1.fc37.x86_64
libpostproc-free-5.1.4-1.fc37.x86_64
libswscale-free-5.1.4-1.fc37.x86_64
librabbitmq-0.11.0-6.fc37.x86_64
libopenmpt-0.6.12-1.fc37.x86_64
libmysofa-1.2.1-3.fc37.x86_64
libmodplug-0.8.9.0-15.fc37.x86_64
libdecor-0.1.1-1.fc37.x86_64
SDL2-2.26.3-1.fc37.x86_64
libbs2b-3.1.0-29.fc37.x86_64
libass-0.17.1-1.fc37.x86_64
ladspa-1.13-29.fc37.x86_64
ilbc-3.0.4-3.fc37.x86_64
libavcodec-free-5.1.4-1.fc37.x86_64
libchromaprint-1.5.1-5.fc37.x86_64
giflib-5.2.1-17.fc37.x86_64
leptonica-1.82.0-8.fc37.x86_64
tesseract-langpack-eng-4.1.0-4.fc37.noarch
tesseract-5.2.0-5.fc37.x86_64
game-music-emu-0.6.3-10.fc37.x86_64
freeglut-3.2.2-2.fc37.x86_64
libcaca-0.99-0.69.beta20.fc37.x86_64
flite-2.2-3.fc37.x86_64
fftw-libs-double-3.3.10-3.fc37.x86_64
rubberband-3.1.3-1.fc37.x86_64
cjson-1.7.14-6.fc37.x86_64
librist-0.2.7-1.fc37.x86_64
libavformat-free-5.1.4-1.fc37.x86_64
libavfilter-free-5.1.4-1.fc37.x86_64
libavdevice-free-5.1.4-1.fc37.x86_64
ffmpeg-free-5.1.4-1.fc37.x86_64
kernel-modules-6.12.39-1.qubes.fc37.x86_64
kernel-latest-modules-6.15.7-1.qubes.fc37.x86_64
kernel-latest-devel-6.15.7-1.qubes.fc37.x86_64
kernel-devel-6.12.39-1.qubes.fc37.x86_64
kernel-qubes-vm-6.12.39-1.qubes.fc37.x86_64
kernel-latest-qubes-vm-6.15.7-1.qubes.fc37.x86_64
kernel-latest-6.15.7-1.qubes.fc37.x86_64
kernel-6.12.39-1.qubes.fc37.x86_64
microcode_ctl-2.1.20250812-58.qubes1.fc37.x86_64
linux-firmware-whence-20250808-1.fc37.noarch
xen-licenses-4.17.5-12.fc37.x86_64
xen-libs-4.17.5-12.fc37.x86_64
kernel-modules-6.12.42-1.qubes.fc37.x86_64
kernel-latest-modules-6.15.10-1.qubes.fc37.x86_64
xen-hypervisor-4.17.5-12.fc37.x86_64
xen-runtime-4.17.5-12.fc37.x86_64
amd-gpu-firmware-20250808-1.fc37.noarch
amd-ucode-firmware-20250808-1.fc37.noarch
atheros-firmware-20250808-1.fc37.noarch
brcmfmac-firmware-20250808-1.fc37.noarch
cirrus-audio-firmware-20250808-1.fc37.noarch
intel-audio-firmware-20250808-1.fc37.noarch
intel-gpu-firmware-20250808-1.fc37.noarch
mt7xxx-firmware-20250808-1.fc37.noarch
nvidia-gpu-firmware-20250808-1.fc37.noarch
realtek-firmware-20250808-1.fc37.noarch
qubes-input-proxy-receiver-1.0.43-1.fc37.x86_64
kernel-latest-devel-6.15.10-1.qubes.fc37.x86_64
kernel-devel-6.12.42-1.qubes.fc37.x86_64
kernel-qubes-vm-6.12.42-1.qubes.fc37.x86_64
kernel-latest-qubes-vm-6.15.10-1.qubes.fc37.x86_64
qubes-input-proxy-1.0.43-1.fc37.x86_64
linux-firmware-20250808-1.fc37.noarch
xen-4.17.5-12.fc37.x86_64
kernel-latest-6.15.10-1.qubes.fc37.x86_64
kernel-6.12.42-1.qubes.fc37.x86_64
python3-xen-4.17.5-12.fc37.x86_64
qubes-input-proxy-sender-1.0.43-1.fc37.x86_64
qubes-gpg-split-dom0-2.0.79-1.fc37.noarch
python3-qubesadmin-4.3.2-1.fc37.noarch
qubes-utils-libs-4.3.3-1.fc37.x86_64
qubes-core-dom0-4.3.3-1.fc37.noarch
python3-qubesimgconverter-4.3.3-1.fc37.x86_64
qubes-utils-4.3.3-1.fc37.x86_64
qubes-audio-daemon-4.3.3-1.fc37.x86_64
qubes-audio-dom0-4.3.3-1.fc37.x86_64
qubes-repo-templates-4.3.1-1.fc37.noarch
qubes-release-4.3-0.6.fc37.noarch
qubes-gui-daemon-4.3.3-1.fc37.x86_64
qubes-gui-dom0-4.3.3-1.fc37.x86_64
qubes-core-admin-client-4.3.2-1.fc37.noarch
qubes-desktop-linux-manager-4.3.3-1.fc37.noarch
qubes-manager-4.3.2-1.fc37.noarch
qubes-mgmt-salt-dom0-qvm-4.3.0-1.fc37.noarch
qubes-release-notes-4.3-0.6.fc37.noarch
qubes-kernel-vm-support-4.3.3-1.fc37.x86_64
qubes-dom0-unwanted-packages-4.3.0-1.fc37.noarch
qubes-dom0-meta-packages-4.3.0-1.fc37.noarch
disk-password-gui-1.0.1-1.fc37.noarch
gpg-pubkey-e99d6ad1-64d2612c
gpg-pubkey-9baef944-680c1fb3
xinput-1.6.4-3.fc41.x86_64
qubes-dist-upgrade-4.2.1-1.fc37.noarch
glibc-all-langpacks-2.40-28.fc41.x86_64
glibc-common-2.40-28.fc41.x86_64
glibc-gconv-extra-2.40-28.fc41.x86_64
glibc-2.40-28.fc41.x86_64
Is that complete list? I don’t see for example xen packages there…
The key part for hitting this issue is sys-whonix as updatevm. It seems to work fine after switching to fedora (like sys-firewall).
Let me try to fix it for whonix too…
Yes, that is the entire output. There is 5 or 6 xen in the output.
I don’t understand what you mean …
Will post in the next days
Hello, I can imagine you have been busy. Any progress with the Whonix pertaining to this issue?
Yes. There has been progress (I was informed by Marek). I believe the issue is diagnosed. But the patch is not yet submitted.
core-agent-linux v4.2.44 (r4.2) Ā· Issue #6177 Ā· QubesOS/updates-status Ā· GitHub should fix it. Whonix gateway needs to be updated with current-testing repo enabled for this.
The problem remains the same, even with the final version 4.3: I am upgrading to version 4.3. Same error, also at stage 3, after
sudo qubes-dist-upgrade --releasever=4.3 --dist-upgrade
I have tried all the suggestions in this thread and always get the same error. I also tried these commands:
sudo dnf remove --duplicates --releasever=41 --setopt protected_packages=
sudo dnf distro-sync --refresh --releasever=41 --setopt protected_packages=
But nothing. The error persists.
I have 6.17.9-1.fc37 kernel, I don’t know if that has anything to do with it.
Thank you!
@marmarek @alimirjamali Hello, sorry for the delay in my replies I have been on a hiatus… My issues still exist now I cannot update/upgrade any of my debian12 vm to debian13 nor whonix 17 via in-place or Qubes updater, Thank you for your assistance.
r@debian-13-xfce:~$ sudo apt update
Hit:1 https://deb.qubes-os.org/r4.2/vm trixie InRelease
Hit:2 https://deb.debian.org/debian trixie InRelease
Hit:3 https://deb.debian.org/debian-security trixie-security InRelease
Hit:4 https://deb.debian.org/debian bookworm-backports InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
1330 packages can be upgraded. Run 'apt list --upgradable' to see them.
user@debian-13-xfce:~$ sudo apt upgrade
Calculating upgrade... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 xen-utils-guest : Conflicts: xen-hypervisor-common but 4.20.2+37-g61ff35323e-0+deb13u1 is to be installed
E: Broken packages
Hello, have there been progress with this that you know of ?
