I followed the link here: Compiling dom0 kernel for notebook from source code guide and it successfully compiled, but I checked /boot/config-x.x.qubes.fc.x86_64 and /proc/config.gz and they show # CONFIG_HOTPLUG_PCI is not set even though in qubes-builderv2/artifacts/sources/linux-kernel-latest/config-base has CONFIG_HOTPLUG_PCI=y
nevermind ill just enable it hotplug pci in config-qubes
Sorry it was because i didn’t enable hotplug pci in config-qubes file, i just forked the repo and put changes in it, and yes i rebooted to run the kernel i just installed by copying the rpm file to dom0, and then sudo dnf install linux-kernel.rpm --disable-repo=*
in the builder.yml instead of
executor:
type: docker
option:
i instead did local cause its in a vm already
executor:
type: local
im not sure if this helps but i also do ssh because github doesn’t accept passwords anymore
You don’t need to authenticate to a public repository.
Yes, config-base is a config taken from Fedora, and then config-qubes is applies on top of it. So, if you want to change something, do it in config-qubes
I don’t quite understand how you were able to cause this behavior. In my case, changing just one line in config-base was enough for the kernel to support the required features after building.
# CONFIG_HOTPLUG_PCI_CPCI is not set
Replace with
CONFIG_HOTPLUG_PCI_CPCI=y
Most likely, the problem lies in how you configured git.
git:
baseurl: git@github.com:QubesOS
Wouldn’t it then pull the official QubesOS repository? I don’t even understand why you even specified a git url there. You need to fork the QubesOS kernel repository, make changes to it, and just let builder download the files from there. I hope the markup doesn’t break, but my yaml config looks like this:
