Qubes and eduvpn
Hi, is there a way to use eduvpn with Qubes? I use Qubes for work, and my institution has disabled the VPN connection via OpenConnect.
Hi JLQubesOS - and welcome to the forum! :slight_smile:
From what I see on:
https://docs.eduvpn.org/client/linux/installation.html#fedora-41-42
I would assume it could work – but assumptions needs to be tested …
:slight_smile:
Thank you very much for the tip! That helped me a lot. I only just got around to trying out the script. It had to be installed in the fedore template, and then I could use it in the sys-net-vm. Once authenticated, I can now access the protected content from my work VM.
