Unlike any Linux distro, even unlike Qubes 4.1x, in 4.2x, Qubes Update tool will break whole update process of a template if Skip_if_unavailable switch is not set at all in the repo def while repo isn’t accesible at the moment (which doesn’t happen very often, hahah).
This simply shouldn’t be the case! Can someone please note the devs about this on github?
Or, in order to be able to update via Qubes Update tool we should set it manually in each and every template’s config?
