Is there any Qubes 4.2.4 or 4.3 reset or upgrade with any USB or SD card.
I am not able to get one. I am already running Qubes 4.2.4 is there anyway to either reset fresh to 4.2.4 cleanly or upgrade to 4.3 without a usb or sd card?
Yes sorry. I mean i am running Qubes 4.2.4 for a couple of months and i want to freshly reset it back to fresh Qubes 4.2.4 or upgrade to 4.3 is it possible to do so without any type of external storage, USB, SD card etc. As im unable to get those
I don’t know if it is possible to reset a Qubes OS install without reinstalling.
You can do an in-place upgrade to R4.3 but it won’t be a reset.
If dom0 is not a concern, you can somehow “reset” your other qubes: install new templates and remove all the old ones. You can also recreate your app qubes.
