Hey Guys,
I’ve been having some weird issues with LVM2 on 4.1 lately.
By default only 20GB is assigned to the ‘root’ LV, I’ve extended this to 60GB however it appears to be related to where appVM data is stored, I would have assumed the vm-pool would be used to store the actual appVM data.
This is what lvs looks like on dom0
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
root qubes_dom0 Vwi-aotz-- 60.00g root-pool 64.79
root-pool qubes_dom0 twi-aotz-- 60.00g 64.80 5.05
swap qubes_dom0 -wi-ao---- 3.94g
vm-pool qubes_dom0 twi-a-tz-- 826.66g 0.00 2.29
Should I simply expand the root LV?
I’m not 100% sure but it looks like appVM data is being stored in the root LV, each appVM used to have it’s own private & root LV however I’m not sure if this is a 4.1 change?
Yeah it appears all appVM storage is now under /var/lib/qubes/appvms, is this normal for 4.1?
Cheers
